Water in rear right footwell area?
  • schtozo
    • 1455
    Hi guys, so i noticed my carpet was soaked with water in the rear right area, lifted the carpet dryed everything and proceeded to do the checkings, i poured water on the sunroof and nothing, then poured on the rear right glass area and bam!
    This is from inside rear quarter panel under the right speaker area, water is making its way in from that area and if the car is parked looking down water is making its way in following the battery positive and into the footwell.
    If car is parked looking up the water stays in the trunk.
    See the water drop in the rear hole
    I removed the rear piece of the shadowline and exposed the 4 holes it snaps into and threw water again and now water got in at larger amounts and quicker so this makes me believe that those holes are the origin of the leak, if it was the weather stripping water couldnt make it into the footwell.
    Anyone with similiar simptoms can chime in and confirm my suspects?
    Thanks
    One of the best threads you will ever read
    http://www.r3vlimited.com/board/showthread.php?t=221813
    Nice trailer of my e30
    http://www.youtube.com/watch?v=TTjtG...e_gdata_player
    If i sold you something please leave feedback here
    http://www.r3vlimited.com/board/showthread.php?t=217142
  • ZM Blue Devil
    • Dec 2006
    • 13836
    windsail grommets, yeap thats it. We see it so often we stock it.
    Levent
    %20levent@gutenparts.com
    Ladies:
    • schtozo
      • 1455
      Thanks levent, this was easy. For now i put tape over the holes. I think i have couple of those laying around i have to double check. Ill let you know of i nee any.
      • schtozo
        • 1455
        Its been 3 days since i dont use te car, and it has been raining since, today i woke up and encountered again the same area in the carpet soaked with water!!
        1- there is rtv and some rubber bumper tabs in place of the windsail grommets plus tape over them.. I did the test with a hose coulpe of times and water didnt leak from there anymore.
        2- car is parked looking slightly up
        3- this is driving me crazy, any suggestions from where the water might be getting in? Ill have to strip the interior to properly diagnose this time i guess.. Aghhhh!!
        • 603Racing
          • Dec 2010
          • 612
          Get the trim seals anyway when you put it back together, they're dirt cheap and will last another 15 to 20 years. Check that your side window and back windows are sealing properly, especially if the rubber stripping looks aged. Pop-out windows have been known to leak even when seals look ok.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
          • schtozo
            • 1455
            I dont have popout windows! I did read in another thread and there is a whole bunch of people with the same leak! Someone did a strong diagnosis for a while and turned out to be the rockers drains were smashed shut thus water acumulated in the rockers and then spilled over the floors from beneath the carpet. This is exactly how mine is leaking, this started like a month ago id say, and a month ago approx is when i plastidipped my rockers which leads me into thinking that paint got into the drains which are like haircracks small, and shut them close. Ill have to inspect this as well and hopefuly is only that, or might it be a coincidence?
            • 603Racing
              • Dec 2010
              • 612
              Good follow up, thanks for posting.
              90 325i DD/Track
              03 Durango 5.9
                • 34844
                yeah, mine does this too. plan to replace before the rain comes back.
                • schtozo
                  • 1455
                  Following up!
                  Windsail grommets are not leaking anymore because its been raining down here and the trunk is clear and dry, BUT the footwell soaked again, it was parked facing slightly up!!! This was like 4-5 days ago, since ive relocated the car to a flat surface raised the carpet dried everything and left if parked outside since, today i went to check on it after 5 days of leaving it, the floor was dry. This is getting annoying but kinda confirming the theory of the rocker drains clogged(when parked looking up water will gather in the rear of rocker and fillup then spill over the floor?). I really feel vague and dont want to remove my interiors to check from were exactly its leaking.
                  My question is where the heck are these drains located as it seems i cant find them.
                  • MC Hammered
                    • Jul 2008
                    • 2076
                    See if either of my threads can help you figure out where your water is coming in from.
                    And if you want to stop the leaking you have to be able to see what is going on under the carpet.
                    My 1989 e30 s52 Touring... this is Betty
                    My 1989 325i vert (sold)...this is Nina
                    My 1991 M5 (sold)... this is Veronica
                    Photo comparison: OEM vs aftermarket windscreen for a convertible
                    • schtozo
                      • 1455
                      Thanks for the tips, but i really need to know where are the rocker drains located.
                      My front end is completely dry, water is getting in from rear area or sure because ive seen water spilling from the corner where the foam is located beneath the carpet corners. Under the rear seat.
                      • schtozo
                        • 1455
                        No luck still! Today i removed the rear seat and quarter panel card and everything there looks fine! No signs of water in the rocker area. Sprayed with a hose the entire side and it passed the test. This is getting frustrating to a point that im not motivated to even look at the car!
