Tach is inoperative
  • ZenkiOwns
    • Jul 2009
    • 496
    Tach is inoperative
    The title pretty much says it.
    I just finished an auto> 5 speed swap on my car and now my tach no longer works. I checked fuse #21 and it's good. I would usually be the first to scream SI board, but I have never had an issue with any gauges etc before.
    I even ran back through every walk through I could find, hoping I missed a plug or something. I don't think I did.
    The MPG meter is also inoperative, but the SI lights are still functioning. If it was the SI batteries, wouldn't these be dead as well?
    HALP?
  • e34john
    • Apr 2006
    • 3599
    Does the econometer work?
    • dnguyen1963
      • Nov 2011
      • 2649
      Did you check the wire from the diff into the back of the instrument cluster?
        • 34839
        It could just be coincidental that your SI batteries went bad. was the car sitting unplugged from the battery for a while? the SI batteries will drain when the board isn't powered from the car.
        you could open it up and check for ~3v if they're lithium batteries. I dunno about the nicads.
        did you do anything behind the instrument cluster or in the dash?
        he said tachometer, not speedometer.
        • ZenkiOwns
          • Jul 2009
          • 496
          Econometer works.
          It was unplugged from the battery for a few days.
          I did not touch the cluster, but that really seems like the only possible culprit.
          The tachometer gets signal from the ecu, not the diff.
            • 34839
            if the econometer works then the SI board should be fine.
            there's one wire from the ECU to the cluster that sends the tach signal. it's black, 1mm, pin 9 of the (round) C101. could check to see if that's getting through. I'd find it odd for the tacho motor to die randomly. could also be a fuse but I'd think the econometer would stop working too.
            • ZenkiOwns
              • Jul 2009
              • 496
              Did a litte research ad I'm going to go ahead and replace the SI batteries. My car is a '91, so I'm "guessing" the batteries are the CR1425OSE correct?
              So all I have to do it remove the tabs from the opposite side of the board, replace with new batteries with tabs attached and voila?
              I'm also wanting to replace my back lighting in the cluster as well. Almost all of them are dim.
              Anyone have a good link to to a replacement walkthrough for those as well?
              • blackhawkimpact
                • 2415
                Might be the cluster's board. That's what happen to me.
                • ZenkiOwns
                  • Jul 2009
                  • 496
                  God I hope not.
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    My bad...allergy season...my brain is in a fog.
                    • ZenkiOwns
                      • Jul 2009
                      • 496
                      I'm about to order the batteries, but before I take everything apart I noticed the SI lights are still on. Wouldn't they be dead if it was the SI batteries?
                      *edited 1st post to include the above*
                      • dnguyen1963
                        • Nov 2011
                        • 2649
                        The green LEDs are supposed to be off after the engine is started. If they stay on, your SI batteries or board is bad.
                        • Gregs///M
                          • Mar 2012
                          • 2459
                          The SI batteries do not directly power the LED bulbs. So the LED indicators can continue to work even when the batteries have been discharged.
                          It is my recommendation to replace the SI batteries if you have any Tachometer/Econometer/Coolant Gauge inaccuracies or intermittent operation.
                          Owner - Bavarian Restoration
                          BMW and European Electronics Repair and Restoration
                          www.BavRest.com
                          My Feedback Thread
                          Our Facebook!
                          Follow our Instagram!
