bouncing fuel guage - already tightened nut behind it
  • clydesdale
    • 631
    I tightened the nut, but it seems worse now. What is the next step? I can tap the guage and the needle will become accurate, until the next bump. Do I need to resolder a connection? What is the usual fix? Thanks.
    • 34844
    there is a 68 ohm resistor right next to the gauge, I'd resolder it and reflow the solder pads around the gauge itself.
    • e30 gangsta
      • 3877
      Try that and if that does not fix it, it may be your fuel level sending unit.
      • clydesdale
        • 631
        Shouldn't the sender be ok since I can tap the guage cluster and make the needle bounce at will? I am hoping it is a resolder issue.
        • clydesdale
          • 631
          It was the resistor. I re-soldered and we are good to go. Thanks.
