ECU question
  • megamythe
    • Jul 2012
    • 52
    ECU question
    I have a ecu ending in 153 but the connector only has 35 pins vs 55 pins...or 2 rows instead of 3. Does this mean that I have a motronic 1.0? This confuses me because I thought those ecu's ending in 153 were supposed to be motronic 1.1. Any information that could help me understand my situation would be helpful.
  • noid
    • 1535
    What year/model is your e30? The 153 ECU is only meant for the M20B25 cars (325i, 325is, 325ix)
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • megamythe
      • Jul 2012
      • 52
      year/model
      It is an 87 325is
      • Etexise30
        • Sep 2012
        • 208
        i need to to count it cuz my ecu used to be a 153 and i got the 173 so i can use my chip with it
          A 153 DME, which would have be the one that came in an 87 325is, has 55 pins in three rows. A DME with only two rows of 35 pins has to be an 027 as used with the ETA engine. An 87 car could have had either engine. Plugging the last 7 of the VIN into realoem.com will tell if the car was built as a 325is (M20B25 engine) or as a 325 (M20B27 engine). But in the 25 years since production someone could have swapped an M20B27 engine (and DME) into a car built as a 325is.
          • megamythe
            • Jul 2012
            • 52
            Well I looked it up on RealOEM and it states that I have a 325i 11/1986 production date with a M20 engine...I believe that this means it should have a m20b25. Still...my ecu has 35 pins and the sticker says 153....is it possible that someone could have done a swap and swapped the stickers?
            • noid
              • 1535
              Take a picture of the engine bay, connector and ECU for us please.
                There is simply no way for a 153 DME not to have 55 pins in three rows. Something strange has to have occurred in the past. If the DME has two rows of 35 pins the engine management system (and probably the engine) isn't that of an M20B25 engine. An 11/87 car could be a SuperETA which would have a different DME.
                  • 34839
                  Super etas have 154 dmes, same version of motronic as m20b25s (1.1), same 55 pin connector and same harness.
