Front wheel bearing replacement
  • Digitalwave
    is a poseur
    • 6282
    Well, one if not both of my front wheel bearings are fucked. I think its only one, because when I turn one way (I forget which) the noise goes away. When I turn the other way the noise remains. If this is the case, is it recommended that I change both, or should I just change the bad one and eventually change the other one if it goes bad?
    How do I tell which one is bad? Say the noise goes away when I turn left, does that mean the right one is bad? If it goes away when I turn left, is it the left one?
    RISING EDGE
  • nickmp0wer
    • 1427
    you should be able to tell which side its comming from but chances are the other isnt far behind
    • Digitalwave
      is a poseur
      • 6282
      Well I don't see any consequences of only doing one at a time, changing one isn't going to put more stress on the other. If the other goes, so be it.
      RISING EDGE
      • DarkWing6
        • Apr 2004
        • 7144
        Wont the wheel with the bad bearing be somewhat loose? If you jack your car up and shake the wheels the loose one will be bad.
        • nickmp0wer
          • 1427
          i dont think i will be loose unless its really bad
          • Digitalwave
            is a poseur
            • 6282
            That's probably not a fair test anyways, since my control arm and tie rod ball joints are both showing signs of wear which will cause play as well.
            RISING EDGE
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              probably cause of those fat spacers you're running.
              • Digitalwave
                is a poseur
                • 6282
                I was waiting for someone to mention my spacers.
                RISING EDGE
                • Dave
                  E30 RAT
                  • 11675
                  TJ,
                  You are dead on with the diagnosis. It is the wheel bearing, and if it goes away when you turn left, it is the right one.
                  It aint the spacers, its the fact that the car is really old, that's all.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • Digitalwave
                    is a poseur
                    • 6282
                    I know it's not the spacers, but some people seem to think spacers affect wheel bearings.
                    Thanks Dave, I figured it was the opposite bearing like you said.
                    RISING EDGE
                      • 34839
                      well they do, to a point (more wear), but not any differently than running wide tires or low offset wheels. but yeah, old cars will have old parts on them, imagine that?
                      I would replace both, as people said the second one is probably not too far behind.
                      • arsevader
                        • May 2005
                        • 1025
                        Be sure to get new dust shields , nuts and grease caps when ordering the assemblies.
                        The axle nut is a 36mm size. NO need for a deep socket.
                        James
                        • e30sd
                          Fistee
                          • Jan 2004
                          • 5517
                          i just like giving him crap, he was super butthurt about it over there...
                          • Brew
                            • 3060
                            Word to that. I did my left one this past August, and the right one kicked the bucket in October.
                            '91 318is
                            • Axxe
                              • Aug 2004
                              • 3355
                              I did them both at once. If you are planning on changing rotors in the near future, now would be a good time if you don't feel like pulling everything apart again. But it's not a bad job it doesn't matter.
                              Keep it slideways!!
