Car won't start! Need R3v on this
  • Cletonius
    • 2809
    Originally posted by London
    No I didn't. Is that crankshaft position sensor? Sorry, don't know the abbreviations. Where is that at?
    If you have an e car as your profile says, there are 2 sensors. One in front by the crank pulley and one in the bell housing somewhere. I have a late model with only one so I can't help on location.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • Cletonius
      • 2809
      Originally posted by dsphil
      Try a new main relay and fuel pump relay. check the grounds too.
      I agree with checking grounds but if his tach doesn't move when cranking, the sensors need to be tested also.
      - Josh
      1990 325is
      Need a shift boot?
      • London
        • 532
        I believe I know which one you are talking about. When I was under the car doing fuel lines I had unplugged and replugged some of those lines. I thought one would be for the reverse lights and mine don't always work. I'll get back under and see if I didn't connect them all the way.
        But would that cause it to run fine one second and then die after I check the sparkplugs?..
        • London
          • 532
          Quick update, car sat all night and this morning I tried it again and it started up. Is it possible that a sensor or something is being shorted out by the coolant thats spilling from the bleeder valve? I should have that taken care of early this week but I'm going to check the grounds and sensors as suggested
          • London
            • 532
            So I checked the grounds and bellhousing sensors. All appear to be fine. Is this the other sensor you were talking about? Follow the wire, I believe this is the camshaft position sensor?
            I pulled that guy out and it was right under where all the coolant was coming out of the bleeder valve. So I cleaned it off and put it back and the car started right up, idled right and seemed to be fine. Could all of my issues have been caused by just that?
            • ghalee30
              • Jul 2011
              • 614
              when my radiator hose blew some of the coolant "dried" over my coolant temp sensor and other sensors . had a rough start and the cluster would act up
              once I cleaned it problems went away
              • London
                • 532
                Ok well now this getting ridiculous. I cleaned that off started the car up and it ran FINE.
                No I go back out there and try it again and nope, won't start at all. It tries, and the tach moves but it just wont get going.
                • London
                  • 532
                  To the top, need this figured out!
                    That sensor on the front of the engine has noting to do with your problems. It exists, on that car, to provide an engine speed signal to the diagnostic connector.
                    Lets go back to basics. What is the rail fuel pressure while cranking? Is there spark wile cranking?
                    • London
                      • 532
                      I couldn't say for sure on fuel pressure. But I know fuel is getting to the fuel rail, and I know I'm getting a spark. Like I said, there have been a few times where it runs fine. And then for no reason a few minutes later it won't even hold idle. Just starts for a moment then stalls.
                        Fuel getting to the rail is not the same thing as correct pressure at the rail. Measure it to find out if this is a fuel system problem.
                        • London
                          • 532
                          How do I go about doing that? Do I need a code reader? Or what?
                          • dnguyen1963
                            • Nov 2011
                            • 2651
                            Tee in a pressure gauge between the fuel line and fuel rail inlet would let you know the pressure.
                            • London
                              • 532
                              Alright, I'll try and get my hands on one. Otherwise I may just be doing that m30 swap a little earlier
                              • London
                                • 532
                                So I double checked the fuel pump relay and the main relay. I'm not 100% sure which is which, but the furthest left is the main relay correct? Anyway that looked like it may have been a little loose. So just to be safe I popped it out and cleaned all the connections. Well the car started up! Woo! Could that have been the source of my problems? Sadly I can't drive it cause I'm waiting on a new thermostat cover. Is there a way to be sure if the relay is faulty or if it was just because the connection was loose?
