My e30: its problems and shady past.
  • coolflow
    • Aug 2012
    • 81
    Since I bought my car a few months ago. I have had always had an overheating problem with it. First it was the waterpump. Replaced that. Worked well for a about a month till something else fucked up. Yep another overheating issue this time it was an old and broken radiator cap. Ok cool fixed that. And now the arrow is pointing at the redZone once again and now my mechanic friend seriously considers its a blown headgasket. To top that off I need 2 new arms for the ball bolts on the tyre, to top it off my friend found out it has an e36 engine in it and probably the odomotres all fucked
    If it turns out to be the gasket should I just sell it?
    Because the further we look into this car the more money I throw at it.
    It's becoming a massive disappointment.
  • Komzorz
    • Jun 2011
    • 332
    What kind of e36 engine? Does it overheat standing in traffic, or does it overheat on the road? Need more information.
    Also, give it a compression test to determine whether it's the headgasket.
    '87 325is - Schwarz/Schwarz
    • coolflow
      • Aug 2012
      • 81
      Both, stopped in traffic it's worse. It'll go down alittle whilst driving but rise up and up.
      It's a 91 model e36 I think.
      Yeah my friends going to come past soon and check it out.
      • mrgraphics
        • 221
        How is the fan clutch? Roll up a newspaper, get the car up to temperature. If you can stop the fan with it, then you need a new clutch.
        Although my overheating problems were all the above: water pump, head gasket, fan clutch, radiator cap, holes in coolant lines.
        • 2ndName
          • Sep 2012
          • 158
          Yeah, unfortunately these cars will need a pretty penny to get it into tip top shape. The people that are having a blast with their E30s as of right now have gone through many dollars and are now in the downhill of just purely enjoying their cars.
          I'm about $2K in and I just bought mine 3 weeks ago...
          • K1CKBAC
            • 306
            Truth
            My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
            • coolflow
              • Aug 2012
              • 81
              ok guys an update
              flame me when you hear this
              so ive been using water since i got it and i drained it and put proper coolant in it
              now it's fine.
              thanks for replies though guys
              I feel really stupid.
              • jeffnhiscars
                • Jun 2011
                • 6011
                Moral of this story is...bleed before you start replacing :-)
                Alice the Time Capsule
                • BrownBeanE30
                  • 965
                  Lol aint that the truth
                  Originally posted by InuFaye
                  silver is old man color car. you need dat BRO-SECA BLUE.
                  so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
                  An S5x is like the girl you want to marry - an m30 is the girl you don't bring home to mom.
                  • future rs
                    • Aug 2012
                    • 514
                    Originally posted by coolflow
                    ok guys an update
                    now it's fine.
                    It wasn't the water. It was probably air in the system.
                    Glad to hear you fixed it!
                    • Kershaw
                      • 11822
                      yeah, water is much better at cooling than actual coolant. it just has this nasty habit of freezing and expanding.
                      AWD > RWD
                      • dnguyen1963
                        • Nov 2011
                        • 2651
                        Water boils at 100C. It is awefully hard to keep it from blowing up in stop and go traffic. 50% Antifreeze actually raises the boiling point of the solution and has better heat transfer rate; therefore, much better coolant than water.
                        • dnguyen1963
                          • Nov 2011
                          • 2651
                          Oh wait, you just saw the viagra commercial where a guy poured a bottle of water into his overheated '69 Camaro radiator, didn't you?
                          • future rs
                            • Aug 2012
                            • 514
                            Yeah 100C = about 215f With a proper cooling system I have never had a car get that high in stop and go. At the track drifting with a small radiator yes.
                            And actually water has better heat transfer than coolant. Glycol lowers the heat transfer properties in water. Guess what! your coolant has plenty of glycol in it. Yes it does raise the boiling point. You where right on that. But its main purpose is to protect against freezing.
                            And a lot of track cars are only permitted to use water. Primarily because of coolants ability to lubricate. You can imagine the dangers a coolant leak on a high speed raceway would cause. Out of all the time I have spent at the track doing road course and even drifting I have yet to have a car overheat or boil over with just water.
                            • dnguyen1963
                              • Nov 2011
                              • 2651
                              You are absolutely right...water has better heat transfer rate.
