Quick!
  • ///M42 sport
    • 3952
    Quick!
    Is it easy to replacing a steering rack boot? My cars in the shop right now and they said it was about $100 to replace. Do you need special tools? I gotta call them back to tell them what I want done.
  • Digitalwave
    is a poseur
    • 6299
    Pretty sure its a piece of rubber held on my zip ties and/or a clamp.
    RISING EDGE
    • redcarbon
      • Apr 2005
      • 213
      but you'll have to unbolt the tie rod from the strut to get the new one on. not hard, but it may take a newbie a bit of time to do if they don't have a puller and jacks and tools and such.
      318is -gone-
      • Digitalwave
        is a poseur
        • 6299
        Ah, thats true. Still doesn't seem like a $100 job to me.
        RISING EDGE
        • ///M42 sport
          • 3952
          I've done suspension and exhaust before by myself so will this be a problem? Do you need to get an alignment after this?
          • Digitalwave
            is a poseur
            • 6299
            Not if its just the boot, you wouldn't need an alignment.
            RISING EDGE
            • 88325isboy
              • Mar 2004
              • 1058
              do it your self.
              '87 325 (Track Rat)
              '04 C5500 Wrecker (Work)
              '94 525i (Daily)
              '90 325i (R.I.P)
              H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
              • ///M42 sport
                • 3952
                Cool, thanks for the quick responses.
                • Alecs MacDonald
                  • 729
                  Just out of curiosity, why does the boot need to be replaced? Has it torn off or what?
                  '88 325ic
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    I would never pay someone $100 to do that job. If you have done suspension stuff already, you should have the tools to jack the car up and take the tie rod ball joint off the strut. Then the boot is held on with either clamps or zip ties. Easy as hell.
                    Will
                    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                    Welcome e30 (brilliantrot '90 325is) 12/23/06
                    DaveCN = Old Man
                    My signature picture was taken by ME! Not by anyone else!
                    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                    • ///M42 sport
                      • 3952
                      Thanks for the advice guys. I replace one this evening. Piece of take, although the passenger side tide rod is stuck to the strut assembly. Anyone have a tie rod puller their willing to let me borrow?
                      • ///M42 sport
                        • 3952
                        It was old and broke apart.
                        • Jordan
                          • 12916
                          Don't ever use a puller.
                          Use a hammer.
                          Hit the strut housing on the outside most corner around the tierod taper. Hit it like a man, don't worry you won't hurt it. Just don't miss and nail your tierod.
                          9 times out of 10 a couple good whacks like this will break the tierod taper free, and it will only require a light tap by comparison on the threads (put the nut back on a couple threads for protection)
                          If by chance you screw up the nut it is m10x1.0
                          https://mtechniqueabs.com/
                          • Victell
                            • 1083
                            Originally posted by Jordan
                            Use a hammer.
                            That works. I loosen the nut so its flush with the top of the threads, and hammer the nut. This prevents damage to the tie rod threads in case you accidentally hit them. Same goes for lower control arm tie rods to spindle.
                            • cthulu703
                              • Oct 2004
                              • 288
                              Large brass drift, a ball-peen hammer, and a dream.
