Need quick help! - How to remove trailing arm bushings?
  • royalflush313
    • Mar 2004
    • 2070
    Title says all.
    What's the easiest way of getting the trailing arm bushings with mostly basic home tools. (Don't have a BMW Special tool, whatever that is).
    The arms are disconnected from the subframe, and ready for the new trailing arm bushings to go on.
    Thanks
    ~ Go Canucks Go! ~
  • kowalski
    • Jan 2005
    • 1791
    Originally posted by royalflush313
    Title says all.
    Thanks
    we have pretty much everything except this bmw "special tool" the one catch is, i can't use a press because i dont have time to take the arm off...
    • royalflush313
      • Mar 2004
      • 2070
      found this link for future reference:
      ~ Go Canucks Go! ~
      • Borat
        • Jan 2005
        • 494
        I just used a standard gear puller, had to hacksaw part off the lip off the bush so the puller could get a grip but came right off.
        • fporro
          • 1860
          this is what the tool looks like, can be replicated with a piece of pipe, a treaded shaft and nut.
          second pic it's tool in action ...
          • mspiegle
            • 1026
            If you do it right, you can use a bottlejack too. Just put the jack in between the 2 arms and use it to push the bushing out.
            My bottle jack is really big and would only work for 1 side. I made a tool for the other side similar to Frank's but used a deep 32mm socket and some long bolts.
            Michael Spiegle
            '01 Ford Escape / Daily Driver
            '99 M3 / Track Car
            '87 325is bronzit / wtf car
            '06 Daytona Triumph 675 / Daily Rider
              • 34847
              I used a 2 jaw puller, basically the same idea except you have to trim a little of the bushing for the jaws to grab onto the trailing arm.
              • fporro
                • 1860
                a friend wants to know if it's possible to swap bushings wthout removing half shafts ?>
                when i did it the whole subframe was removed to do other work.
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Well yeah, but how do you put the new bushings on? Can you squeeze by without trimming it? I know that when you're removing them, you dont care because you're discarding them anyway, but how do you install them with the jaw pullers?
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • fporro
                    • 1860
                    oops, forgot to mention, we'll use the k-mac tool (a few posts above this one) and urathane off centered replacements, they slide in without much fuzz.
                      • 34847
                      I dunno, I used urethane bushings, they slid right in.
                      • kowalski
                        • Jan 2005
                        • 1791
                        me too, i like the urethane stuff. i got it done thanks guys! she will be running tomorrow with all new bushings. (every single rubber bushing front and rear has now been replaced:)) i forgot to take pics tho, but i like seeing the gree IE bushings in the subframe! and yes you could do the controll arm bushings without pulling the subfram, or the halfshafts, it would just be a serrious pain in the ass.
                        atleast it looks like you would be able to...
                        • Garageaholic
                          • Dec 2005
                          • 5204
                          You did the rear subframe bushings too? were they a bitch to do? And they were urethane?
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          • royalflush313
                            • Mar 2004
                            • 2070
                            bitch is an understatement. Only good thing about urethane is that it pops in without any hesitation.
                            ~ Go Canucks Go! ~
                            • ak96ss
                              • Nov 2005
                              • 461
                              Rubber goes in easily as well - just stick the bushings in the freezer overnight, then heat the subframe up with a torch, hit it with PB Blaster or white lithium, then slide them in.
                              I replaced all the bushings in the rear with just a puller and some plumbing stuff (end caps). Worked well, and didn't take a long time to do.
                              I considered urethane bushings, but I have heard (somewhere, sometime...) that they don't age gracefully. IOW, when they go, they go, and there is no gradual worsening of the handling.
                              I have no evidence to back this up, but I figured the originals lasted 180K+ miles, so they can't have been horrible. Cheaper, too.
                              FWIW.
                              John in MD - 1991 318is
                              190k miles and still rolling!
