Need quick help! - How to remove trailing arm bushings?
  • Axxe
    • Aug 2004
    • 3355
    Realistically, urethane will out last your car.
    Keep it slideways!!
    • fporro
      • 1860
      unless is overtighten as on rear shock mounts, please don't ask how i know.
      • kowalski
        • Jan 2005
        • 1791
        Originally posted by ak96ss
        Rubber goes in easily as well - just stick the bushings in the freezer overnight, then heat the subframe up with a torch, hit it with PB Blaster or white lithium, then slide them in.
        I replaced all the bushings in the rear with just a puller and some plumbing stuff (end caps). Worked well, and didn't take a long time to do.
        I considered urethane bushings, but I have heard (somewhere, sometime...) that they don't age gracefully. IOW, when they go, they go, and there is no gradual worsening of the handling.
        I have no evidence to back this up, but I figured the originals lasted 180K+ miles, so they can't have been horrible. Cheaper, too.
        FWIW.
        the urethane i didn't have to freez, or use lube to get them in. they just pushed in with my hand. and i'm driving her today! and what a pleasure it is, new brakes, new rotors, stainless braided lines, ate super blue fluid. new trailing arm bushings (urethane), sub frame mounts, sway bar bushings, sway bar links. IE shock mounts. SSK, and the cherry on top is a nice new OEM shift knob.
        • royalflush313
          • Mar 2004
          • 2070
          haha Mike, now that I think about it, we did install a whole shit loads of stuff in your car. No wonder it took so long.
          We know what we are doing now though, so we should be able to cut the time in half :o
          ~ Go Canucks Go! ~
          • kowalski
            • Jan 2005
            • 1791
            yes, yes we did. we knew what we were doing before;) but now we know how to deal with the siezed bushings... and more efficient ways to do it.
            • Sean
              • 5793
              Originally posted by fporro
              this is what the tool looks like, can be replicated with a piece of pipe, a treaded shaft and nut.
              second pic it's tool in action ...
              almost identical to what I did! Works great! :D (I did the pipe and bolt...)
              - Sean Hayes
              • fporro
                • 1860
                cool
                she"s got another run, last weekend we were able to swap out bushings without removing half shafts nor brake lines ;)
