Remove check engine light for smog?
  • 325Drew
    • Oct 2012
    • 180
    Im in the process of registering my 86 325es and its come to smog. Check engine light is flashing and my mechanic friend said all i have to do is take out the bulb to pass? not sure about this but seeing how the car is over 25 years old it may not be required? and if so how do you remove it? thanks for any help and sorry for the noobieness. just got the car running after sitting since 04 so i am antsy!!
    1986 325es
    1998 328is
    2000 toyota 4runner
  • reelizmpro
    • 9552
    There is no check engine light on 325eS.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      • 37833
      ^ What he said!
      Also, your friend is an idiot. Any car that is supposed to have a check engine light will automatically fail if it has been removed or is not functioning.
      Grover Beach, California
      BimmerHeads.com
        If the light that is flashing has CHECK on it and is in the center of the cluster above the row of lights along the bottom, it is the Check Panel warning light.
        • 325Drew
          • Oct 2012
          • 180
          yes it is just the word check. does it matter if it is flashing for smog?
          1986 325es
          1998 328is
          2000 toyota 4runner
          • 325Drew
            • Oct 2012
            • 180
            thanks for the help tho guys, some mechanic he is.....
            1986 325es
            1998 328is
            2000 toyota 4runner
            • reelizmpro
              • 9552
              People not familiar with BMW's will often assume the blinking "CHECK" light in the cluster is a check engine light but it's not.
              88 M3 - LACHSSILBER
              • 325Drew
                • Oct 2012
                • 180
                i got it, pushed the check button and it went away.
                time to smog!
                1986 325es
                1998 328is
                2000 toyota 4runner
