What oil (not brand)
  • CarsSuck
    • Oct 2005
    • 968
    Im currently using a 15w50 Mobil1 syn. It seems to be a bit heavy in the cold (early mornings below freezing, not uncommon to see the teens). What do you guys run in the winter and what do you run in the summer? I was thinking a 10w40 would be better, but im a tad worried about developing small leaks.
    --Will
  • Brew
    • 3060
    10w40 is just fine for your motor. Definitely get that 15w50 out of there before the temps start to drop below the 30s at night.
    '91 318is
    • CarsSuck
      • Oct 2005
      • 968
      HAHA waaayy too late for that.
      --Will
      • Mystikal
        Wheel Fitment Expert
        • 9602
        5W-50 Castrol Syntec.
        Incredible stuff, no sacrifices. That said, I still switch to 15W-50 Mobil for summer.
        • mark1
          • Oct 2005
          • 93
          0-40 M1
          • Axxe
            • Aug 2004
            • 3355
            0-40? Where do you live, siberia? That's one of the first oils to break down, it's got such a huge spread.
            Keep it slideways!!
            • DaN
              • 1265
              I was looking at the e30 owners manual, it said 15w-50 is useable down to about 0 degrees F. I currently have Mobil 1 15w-50 in my 325i. I don't think I'll change it. I just let it circulate a minute before driving.
              The synthetic stuff flows nicely at low temps.
              • CarsSuck
                • Oct 2005
                • 968
                Well when its down in the teens i can tell at start up that the oil is thicker than sin because it turns over slowly and doesnt want to rev until it warms up. just to make sure im thinking correctly, the first number is the warm viscosity and the second is cold, right?
                --Will
                • hamann318is
                  • 3382
                  I use 15w50 most of the time. The local BMW shop told me that's all they run in the M42. I ran 10w40, and I was getting some very small leaks.
                  The BMW 318 is back. With a vengeance.
                  • DaN
                    • 1265
                    The first number is the viscosity at colder temps, w- winter. Second is operating temp.
                    I doubt the oil is slowing your crank speed.
                    • mrsleeve
                      • Mar 2005
                      • 16387
                      I bet it is on verry cold morrings.
                      Originally posted by Fusion
                      William Pitt-
                      • DaN
                        • 1265
                        nah
                        • Mystikal
                          • 9602
                          I still had my 15W-50 in as the temps went down to 40-50, and the entire week after I changed to 5W-50 I couldn't believe how different the car behaved when cold.
                          15W-50 is too much for our climate man, get it outta there.
                          • DriftinE30
                            • Nov 2005
                            • 4
                            I 2nd that.
                            • 318i1985
                              • Dec 2005
                              • 50
                              I'm running 15w40 Royal Purple with no complaints
                              Check my Car Domain site
