What oil (not brand)
  • optimusp517
    • Oct 2005
    • 797
    #31
    I think I'll stick with what the service shop has been using I believe it's 15w50
    I could be wrong...
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #32
      Originally posted by Jordan
      I run the same oil in my 2.8l
      Do you have any problems burning it off? I used to think it was bad valve stem seals letting it in but now that I have a brand new head/guides/seals its definately rings. Total seal rings do a less then stellar job with thier oil scrapping job, but my compression is all 200-210.
      I think I'm going to switch to 20w-50 this weekend and see if that halts the problem. I've never had an issue burning oil until I swtich to the 5w-50 Syntec.
      I can't tell for sure yet. I've only been using it for 4500km on the new head, and my oil pressure sender has a small leak around its seal. Of course this happened about a week after the oil change; I'm planning to put a new one in at the next oil change (next month sometime).
      That said, I haven't lost any significant amount of oil in all that time despite that annoying drip. With the old head I was burning a quart every 1500km, so I really don't think I'm burning any of the 5W-50
      My rings are still OE with 324k.
      • arsevader
        • May 2005
        • 1025
        #33
        Make sure it's the seal of teh sender and not the sender body itself. They are notorious for cracking and allowing oil to seep out and up the harness.
        James
