My sunroof has been leaking since I got the car (87 325e)...I pulled the sunroof out today and cleaned all the drain holes and they flow very well...reinstalled the sunroof and even aligned it better than it was before, it now sits perfectly flush with the body.
So, I washed it just to test how well it kept water out, and it leaks worse. The seal around the outer edge is indeed damaged, but, I was told that was just for wind noise...does that seal keep water out and the drains just for what trickles past? Or is there something missing from mine?
Also, the inner panel (one with headliner on it) is pushed all the way back into the roof. More or less my sunroof is broke and doesn't work so I had to push that out of the way to remove it. Is that part of the seal?
I'm just lost...I had the thing off and saw nothing to keep water out :/
