Trunk lid sweats...?!
  • withinward
    • Jul 2012
    • 90
    So i live in Seattle and it's now cold and rainy, surprise surprise.... BUT, opening my trunk today, I noticed A LOT of condensation on the top of the inside of the trunk lid. Is there a way to remedy this?
    Sent from my SCH-I535 using Tapatalk 2
  • withinward
    • Jul 2012
    • 90
    Also have noticed a lot of water accumulation in the left side of the trunk. I suspect the antenna or body moldings near the quarter windows. Anyone have experience fixing a leaky antenna?
      Fixing a leaking antenna is easy, replace the grommet. The other common problems relating to the trunk are the tail light seals and then the trunk seal. Of those two, the tail light seals are more commonly a problem.
      • withinward
        • Jul 2012
        • 90
        Right, I've read about those 2, but I'm getting a lot, like the whole inside of the trunk lid covered in drops of water.
        • ELVA164
          • 4861
          Another possibility could be the seals on the sides of the trunk, under the rear bumper. And the condensation can be caused by the standing water in the trunk evaporating.
          • rav320uk
            • Jun 2004
            • 1337
            I would check you rear light seals, as these perish over time allowing water to drip inside, most common cause over here.
            Lift up your carpet and slowly pour water over the top of the light from the outside, if they are perished, you'll see the water beading inside.
            If you have bought items from me, please leave feedback below.
            If you are a BUYER, Check My Feedback.:up:
            http://www.r3vlimited.com/board/showthread.php?t=183860
            Check out my Euro Build Thread
            http://www.r3vlimited.com/board/showthread.php?t=215557
            • withinward
              • Jul 2012
              • 90
              Cheers, thanks for the responses. I'm going to tackle it this weekend. Can't stand the thought rust starting on the ole girl.
              • AndrewBird
                The Mad Scientist
                • 11898
                Your sunroof also drains down into the trunk and into some plastic fittings on the side of the trunk under the bumper. Make sure the hoses are still attached and the plastic parts are in place.
                You can also buy water absorbing things to help get the moisture out. I bought a few from Lowe's out of the closet section. They are basically a plastic tub filled with moisture absorbing gravel type stuff. Just leave it in your trunk when you are parked.
                • TobyB
                  • 5296
                  me too.
                  t
                  • withinward
                    • Jul 2012
                    • 90
                    Sunroof drains are clear. New trunk seal and antenna grommet on the way. I had the taillights off recently and the seals seamed fresh, but who knows.
                    • withinward
                      • Jul 2012
                      • 90
                      When I finally find the source of this condensation, I intend to shame it woefully hard with my best irish accent.
                      • frankie591
                        • Feb 2012
                        • 545
                        the grommets where the sidemarker light wires exit the trunk were leaking on my car
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          There is a drain slit just under where the jack sits and it gets plugged. I cleared mine with a small slotted screwdriver.
                          Alice the Time Capsule
                          • Sindako
                            • Nov 2012
                            • 116
                            That Sounds Legit .
                            Every E30 Owner Have the same problem .
                            Thank God Not Me .
                            • withinward
                              • Jul 2012
                              • 90
                              Weird, I've looked and can't seem to find mine. You have any pics per chance?
