Door lock
  • Beemerdan
    • Nov 2012
    • 192
    Door lock
    I have a 1991 318i vert, and the drivers side door will lock and unlock with the pull thing inside, but will only unlock from the outside. Also if I lock it from the inside first it wont close. Any ides on what might be wrong?
    Thanks!
  • 89 e30
    • 249
    Why would you wanna lock it from the inside? Nobody is gonna break in when you are in the car
    BIMMER für IMMER
    • Beemerdan
      • Nov 2012
      • 192
      What I meant is that I can't even lock it from the inside then close it when I park it, so basically there is no way to lock it.
      • jeffnhiscars
        • Jun 2011
        • 6011
        You are not supposed to be able to lock the drivers door from outside without the key so you cant lock yourself out. If you close it and a passenger pushes the button down, it will lock
        Alice the Time Capsule
        • Beemerdan
          • Nov 2012
          • 192
          That makes sense, but it wont even lock with the key.
            • 37832
            Then fix your lock or buy a new lock set.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
