Any lubricants safe for fuel hose?
  • SlamedIAm
    • May 2011
    • 318
    I just replaced my fuel tank for the second time and now I'm in the process of buttoning everything back up. A few of the hoses (specifically the braided vent hose) are a real pain to get back on. Are there any lubricants safe to use that won't deteriorate the lines? Thanks.
    Any water based lubricant is fine (liquid soap, cable pulling lube, etc).
    • bmwstephen
      • 2463
      wd40?
      • jeffnhiscars
        • Jun 2011
        • 6011
        Originally posted by bmwstephen
        wd40?
        No..definitely no. Read the label, smell that stuff, ask yourself if its water based then follow Jim's guidance
        Alice the Time Capsule
        • frankie591
          • Feb 2012
          • 545
          just use dish soap and water
          • TobyB
            • 5296
            "snot" or cable pulling lube is great- it's water- based soap, and slicker than... yup, snot.
            Or you can use fuel. Diesel works pretty well, altho it's probably not the best for the hose.
            t
            • ELVA164
              • 4861
              We always use a quick shot of brake parts cleaner to lubricate our hoses. It works well and evaporates very quickly without leaving residue.
              • dashboardmonkey
                FUCK YOUR WAFFLES
                • Jun 2008
                • 6158
                Spit on it.
                Giggidy
                -Andy
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Considering the small about that will be used, any lubricant will be fine. The hose won't be bathed in the stuff for an extended period of time. That is when you need to worry about it.
                    • 37833
                    Dish soap is the way to go!
                    Grover Beach, California
                    BimmerHeads.com
                    • SlamedIAm
                      • May 2011
                      • 318
                      Thanks guys. Went with dish soap and it made a huge difference.
