Blower motor question.
  • dwvw
    • Sep 2011
    • 234
    My blower motor is on it's way out. The bearings on the shaft on one side has a ton of play. I don't want to spend a fortune on a new one but looking at localish auto wreckers is confusing me. My car is an '87 325e. Do I need the aluminum (siamesed water inlet) or plastic (separate water inlet). Or does it matter. When I had it apart it was a Behr unit for sure.
  • vert_this
    • Feb 2012
    • 395
    I'm confused too cause I wasn't aware the blower motor had any water inlet.
    • reelizmpro
      • 9558
      You are talking about two different things so no...it doesn't matter. What could matter is the 3-4 speed blower. I think only the very early 318i and 325e had 3 speed blowers. Try to get a 4 speed blower as it will have the correct resistor pack already on it.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • dwvw
        • Sep 2011
        • 234
        I'm assuming it's referring to the heater core, and that maybe there was a slight difference in the blower motor based on which heater core you had. My car has 3 fan speeds.
        • reelizmpro
          • 9558
          Does your car have ac? If so, u have the aluminum pipes and siamesed inlet/outlet core.
          88 M3 - LACHSSILBER
          • dwvw
            • Sep 2011
            • 234
            No AC.
            Does it really matter for the blower motor though?
            • Stanley Rockafella
              • Aug 2011
              • 4062
              Originally posted by dwvw
              No AC.
              Yes, it really does
              this is the most common setup. on both my 86 325es and 88 325is that had ac from factory, they both have the same motor
              yours on the other hand, seems to have the blower unit listed in this schematic
