Odometer, Speedometer and mpg meter only working occasionally, how to fix?
  • Prost
    • Nov 2012
    • 193
    My odometer, speedometer and the mpg meter (dunno what to call that, the one below the RPM meter) are not working when the car is cold...it will work occasionally when it warm up, anyone know how to fix that? Do I need to rebuild the whole thing?
    92 Alpine White 325iC M-Tech II Appearance Package
  • N2MYE30
    • Oct 2007
    • 5536
    Not exactly your issue but its a start.
    COTM
    • McGyver
      • 4634
      ^yeah, SI board batteries
      • Prost
        • Nov 2012
        • 193
        Originally posted by N2MYE30
        http://www.r3vlimited.com/board/showthread.php?t=272374
        I think this is my issue...how hard is it to replace it myself?
        • TurboJake
          • 3780
          Easy peasy
          Leave Me Transaction Feedback
          • Gregs///M
            • Mar 2012
            • 2459
            Odometer and speedometer are not interfaced with the SI board. So you will have to troubleshoot those separately.
            Consider re-flow of solder on the cluster main board. However, change your SI board batteries first.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • Prost
              • Nov 2012
              • 193
              My mechanic said that there is a metal "wire seal" thing on the odometer/speedometer thing (similar to the wire seal on electrical meter at home to prevent temperating), since my E30 has low mileage, should I break the seal and check for problem? On the other hand, it probably show that the low mileage is true reading and not something to make up by the previous owner...:p
              • e30slidewayz
                • 813
                replace SI batteries, check solder joints, check ground nuts... many many write-ups on these procedures with images
                • Prost
                  • Nov 2012
                  • 193
                  No need to replace the battery...my mechanic will take out the housing from near the rear differential and clean the sensor for me, most likely a dirty sensor...the wire seal is not something there to prevent tampering...
