Better coolant tank for the E30?
  • lowsodium
    • Dec 2012
    • 289
    Does anyone make a coolant overflow tank for the E30 that isnt so big and ugly? I have the big one that mounts to the shock tower like in the below pic.
    It would be nice to have one that mounts to the side of the radiator like I have seen on E36's. I searched, but couldnt find a thread about this.
    Haven't you ever seen Russian Nesting Dolls? They work like that.
    1987 325e / 2008 135i
    • 37833
    You could always switch to a M42 radiator which has an internal tank.
    Another option is to swap to a late model cooling system with the expansion tank mounted on the driver side fender well.
    Grover Beach, California
    BimmerHeads.com
    • roguetoaster
      Biggus Tippus
      • 7830
      Read this about the M42 radiator conversion.
      Not worth it for cosmetics, but if you happen to say "accidentally" crack your current overflow tank you could probably talk yourself into it.
      • lowsodium
        • Dec 2012
        • 289
        Thanks guys! Hopefully I can get rid of this ugly thing soon.
        • TobyB
          • 5297
          Ironically, the M42 and E36 and E46 tanks explode periodically, often with help from the cap.
          The E30s don't seem to.
          t
          • peytonracer4
            • May 2011
            • 524
            t
            as far as i know those tanks are all under pressure as they're directly connected to the radiator.
            is the e30 stand alone tank under that much pressure?
              The E30 cap lifts at 17.6psi, and the E36 M42 cap lifts at 29.4psi. So the E30 cooling system is under lower pressure, which explains when they seldom burst when old (service life of the cooling system is 10yr/100k).
