My car clanks a little when i take off and when i feather the throttle at low speeds im trying to figure out if its the drive shaft or something else. When last I lifted my card i was able to grab the drive shaft and it slightly moved when i wiggled it. I was told its more an an annoyance than a need to fix. Also I think my driver side rear axle is worn out as well. When I grab it. I am able to move it a little before the diff starts to turn the other side. now do i need a new Diff or a drive shaft of the axle or just say to hell with it and replace it all?
I hear clanking when taking off
Driveshaft bolts, Guibo bolts, locking collar nut on driveshaft, csb, diff--in approximate order of likelihood.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)
Center support bearing.
Couldn't find one on blunt tech, so check: http://www.turnermotorsport.com/BMW-...-bearings.aspx
I havent been able to check yet cause its cold as the north pole out but just to be clear when i take off it goes CLUNK and if i feather it it goes clunk clunck clunk, when i drop speed and pick it back up it makes the noise not wile accelerating or decelerating. if that makes sence.Float like a cadillac sting like a Bimmer!:)
