engine wont turnover
  • nickmp0wer
    • 1427
    Im trying to turn the engine over to break the crank bolt loose. It wont turn. With the key or with a screwdriver (the 2 posts on the solenoid righ?) . I'm thinking this is probably becasue i have a whole bunch of stuff disconnected. Anyone knows what all needs to be present for an engine turnover?
  • parkerbink
    • Jun 2004
    • 10138
    Mechanic + car.
    • PeaveyBassist
      • Sep 2004
      • 3511
      Why do you need it to turn over? I thought you couldnt drive now.
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • nickmp0wer
        • 1427
        now i can
        i replaced a motor mount which has a ground on it, but ive cheacked and rechecked that, could it be it?
        • Pedro
          • 965
          did you put the crank and cam sensors back correctly? no crank sensor = no crank
          ps i dont know whats you've been doing to the car but if you disconnected those then maybe thats a problem.
          http://www.volkswagenjettacup.com/
          • PeaveyBassist
            • Sep 2004
            • 3511
            No crank sensor = no start. It would crank, but not start.
            Will
            DaveCN = Old Man
            • nickmp0wer
              • 1427
              I just disconneted the ground i thought i messed up, to see if it would make a differnece. it engaged the soleniod but no crank. I hooked it back up and when i connect the posts with a screwdriver it just makes a bunch of sparks?
              • nickmp0wer
                • 1427
                anyone know? i dont know what could casue this?
                • nickmp0wer
                  • 1427
                  i connected the mounting points of the electical box thing that goes under the intake mani to ground, and now when i connect the posts the starter will spin but the solenoid wont enguage. I guess i will wait till most of it is back together then try it then?
                  • PУCCKAЯ_e30ka
                    • Jan 2006
                    • 1226
                    get a bentley
                      • 37833
                      Good lord man, don't tear the car apart if you don't know what you're doing
                      Grover Beach, California
                      BimmerHeads.com
                      • kowalski
                        • Jan 2005
                        • 1791
                        i agree
                        also if the starter is spinning, but not shooting out the starter is shot.
                        • nickmp0wer
                          • 1427
                          I know what im doing with all the gaskets and stuff, but like everyone else, I dont know what the deal with the starter is
                          • Joe318is
                            • Sep 2005
                            • 6451
                            Dont use the starter to break the bolt loose, thats one sure fire way to find yourself replacing a starter! There are a few products out there that can be used to keep the motor from rotating, one even screws into a spark plug hold and stops the piston from moving up. However i would have someone stick a flathead screw driver in the teeth for the starter gear, ring around the flywheel. Takes a bit more work, remove the inspection plate at the back of the oil pan, or the starter itself.
                            Originally posted by vlad
                            • nickmp0wer
                              • 1427
                              A screw driver against flywheel teeth for 230lbs for force? i think not. I ended up just not replacing the crank seal or lower timing case gasket. I dont think they were leaking anyways. Im going to run the car with just water in the cooling system for a few days. That way if there is a leak i dont have to deal with $20/gallon coolant.
                              Oh and now that i got it back together the starter works fine. What caused it not to work? the world may never know...
