a/c clicks unless recirculation is on
  • chuckybob
    • Aug 2004
    • 952
    my a/c clicks unless recirculation is on. it doesnt matter if the a/c is on, off, or what the heat level is. it clicks 3-6 times a second, very loudly and plasticy. what can i do to get rid of it?
    (i dont think its the beehive, james)
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
  • DaN
    • 1265
    Just want to get rid of it? Unplug the wire going to the a/c clutch coil.
    • Nick325is
      • 1409
      sounds like the clutch on the compressor could be going bad. My gf's car did that when the ac clutch was going out. If that is the case you need a new compressor.
      Nick
      • Tangent
        • Mar 2004
        • 476
        The part where it only does it if recirc is not on makes it seem like it's not a compressor problem to me. Try another switch.
        • James Crivellone
          Head Janitor
          • 6302
          recirculation activates two servo motors which close 2 plastic doors on the outside of the heater box.. Sounds like when they are open something is rubbing on the blower motor.
          • chuckybob
            • Aug 2004
            • 952
            necro post and all, but i'm finally getting around to addressing this issue tonight. is there a way to check the affected area without pulling the whole dash?
            • Tangent
              • Mar 2004
              • 476
              Can you get it to make the sound with the ignition on but without actually running the engine? Without the noise of hte engine you should at least be able to narrow down exactly where this clicking is coming from, if it's the fan inside the dash or the clutch on the compressor, or something else entirely...
              • e9nine
                • 1890
                What's happening in this dude's case is the one of the plastic doors is stuck and thus unable to open when the recirculate button is closed. Take out your radio and you will see a little road connected to a "flap" moving as it tries to open. You can either disconnect it or play with it and see if you can get it to work or you can replace the servo.
                Good luck.
                • chuckybob
                  • Aug 2004
                  • 952
                  thanks a bunch!
                  • NC325iC
                    • Mar 2004
                    • 6565
                    just leave recirculation on then
                    • chuckybob
                      • Aug 2004
                      • 952
                      that's great in theory, but it keeps the a/c motor running and pwnz my battery after 4-5 days
                      • NC325iC
                        • Mar 2004
                        • 6565
                        i only said it cause it had to be said
                        • DaN
                          • 1265
                          It doesnt shut off when the key is off?
                          • chuckybob
                            • Aug 2004
                            • 952
                            it shuts of and turns on whenever it damn well pleases. some nights, id turn the car off, itd click for 30 seconds then stop. other nights, turn the car off, went right off with it and then the next morning, id go out to the car to find it clicking.
                            • kkamakasi
                              • Sep 2009
                              • 202
                              Good luck.
                              This is the problem I am having as well and e9nine's response seems spot on. It is def not the ac clutch. The flap motor seems to want to open one of the flaps but due to it being stuck, the motor just keeps turning and clicking (skipping plastic gears).
                              So all I need to do is remove my radio and I should be able to see the flaps and whatnot?
                              So this problem can cause the blower motor to stay on constantly when the car is on? Cause that is another issue that I am having... even if the AC is set to "off" so no air should be coming out of the vents, there is air coming out of the vents...
