Stupid Electical Problems!!!!!
  • e30 gangsta
    • 3877
    OK MY cig lighter decides to work when ever it wants. The fuse is fine and sometimes it just stops working. I replaced the little medal holer thing that holds the cig lighter. Still the same problem. IM mad as hell right now can anyone help me out!???
  • chuckybob
    • Aug 2004
    • 952
    its a wiring problem for sheezy. check the bentley for a wiring diagram of the power door locks and the cig lighter and look for common junctions that might be having problems.
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • e30 gangsta
      • 3877
      anyone else?
      • BENdashdash
        Tom is not my friend
        • Aug 2004
        • 2506
        Is your AFM plugged in?
        j/k Loose ground? I'd trace the wires and see what can be found. You can also try rerouting the ground wire.
        • e30 gangsta
          • 3877
          which ground wire ?
          • asubimmer
            • 6482
            cig ground?
            • e30 gangsta
              • 3877
              Originally posted by asubimmer
              cig ground?
