What do you idle at?
  • MitchFong
    • Sep 2005
    • 665
    my car is idling at like 650. Seems a little low, as my other cars are all around 1000.
    Just wondering if i should turn it up a little bit, its sometimes quite rough when stopped at an intersection.
  • tommyboy
    • Oct 2004
    • 162
    Assuming we're talking about your m20b25...
    The factory idle spec is 760 +/- 40 rpm, I believe.
    650 sounds a little low, and 1000 sounds quite high :)
    If you consistently idle at 650, I'd say turn it up. If not, check idle position sensor?
    • MitchFong
      • Sep 2005
      • 665
      mm i cant find anything about the idle sensor in my haines manual.
      My idle will usually sit around 650, but can drop sometimes.. But for the most part its right on 650.
      • Aytah
        • Dec 2005
        • 69
        My eta revs at 800, unless its cold, then it revs at 400 then 900 then 500 then 900 then 600 then...well you get the picture
        Jager + Red Bull = Enhanced ladying abilities
        • permit
          • Mar 2005
          • 3363
          550...muahahaha.
            • 34839
            650.. 1000 is way too high for an M20.
            • MitchFong
              • Sep 2005
              • 665
              so should i just leave it where it is currently? feels low when im stopped at a light.
                • 34839
                you're fine. the M20 will idle all the way down to 300rpm, technically. as long as it doesn't fluctuate I'd leave it alone.
                • James Crivellone
                  Head Janitor
                  • 6304
                  Right at 650
                  • Jordan
                    • 12913
                    650 is just fine.
                    There is no real adjustment anyways.
                    https://mtechniqueabs.com/
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      As far as it feeling rough, when was the last time you changed your spark plugs? What about your cap and rotor? Simple things like this will make a world of difference if not kept up with.
