dead battery, trunk lock fucked!!
  • ///M42 sport
    • 3952
    what are my options if I cant get my trunk to unlock...the lock cylinder wont fucking turn!! So fucking pissing me off
  • FLG
    • Sep 2011
    • 3165
    Pop the hood, connect a charger/battery/jump to the positive connections under the hood on the passenger side firewall.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • ButtJuice
      • Dec 2009
      • 2609
      Shouldn't the lock turn regardless if there is power or not?
      1991 318is - Sold
      1986 325 - Sold
      Instagram - Lamoursum
      • ///M42 sport
        • 3952
        what would the positive connections be?
        the lock wont turn bc its a mechanical failure. 2 seperate issues and somehow the fucking universe aligned and fucked me over
        • jclar
          • 265
          Remove the rear seat and go through the ski pass, assuming you have it punched out. I once did this at about 2AM in the middle of nowhere because I locked my keys in my trunk.
          The lock will turn regardless of battery charge. I'm not sure if there's a way to actually open it from the inside.
          '86 325es M50
          • FLG
            • Sep 2011
            • 3165
            Yes it should, im assuming his lock is jammed and since the battery is dead the central locking is not working either.
            Passenger side firewall, the junction box.
            Edit: Right, i figured your lock is not turning due to a mechanical failure. Of course it has nothing to do with the battery being charged or not.
            Found a pic
            • ButtJuice
              • Dec 2009
              • 2609
              Oh, I see your problem. fuuuuuuuuuuuuuuuuuu that sucks.
              I have no idea how to logically solve this problem, but get some power tools and show the lock cylinder who mo'fckin boss.
              Then go to a jyard and pull another one, then get a key made for it. Perhaps someone is selling a lock set some where on the forum.
              1991 318is - Sold
              1986 325 - Sold
              • FLG
                • Sep 2011
                • 3165
                Most likely an issue with the tumbler, id imagine if you get power and hit the central locking the trunk will open again.
                • ///M42 sport
                  • 3952
                  My ski pass isnt punched out. How do I go about push starting it?
                  • jclar
                    • 265
                    You can jump at the junction block as mentioned before. By push starting I assume you mean popstarting?
                    Put the car in 1st gear and depress the clutch as somebody pushes the car. When you get up to about 5mph(not terribly difficult) ease off the clutch. Make sure your ignition is set to on.
                    '86 325es M50
                    • FLG
                      • Sep 2011
                      • 3165
                      OK
                      Im assuming your central locking is not working due to a dead battery which in turn has you using the key to open the trunk, which is not opening due to a mechanical lock issue correct?
                      If so, no amount of push starting will work. The battery is simply too exhausted.
                      Do you get anything when you try to start it? If you dont get a click or a half attempt at turning over the motor, the only thing push starting it will do is make you tired.
                      • ///M42 sport
                        • 3952
                        yeah I get something, the starter kicks in for a sec then dies.
                        • FLG
                          • Sep 2011
                          • 3165
                          Then you could probably just pop start it.
                          Sent from my Galaxy Nexus using Tapatalk 2
                          • unevolved
                            • Nov 2011
                            • 714
                            I usually get better results push starting in 2nd gear, that way the car doesn't try to take off when the motor catches. Also try popping the clutch rather than slowly letting it out.
                            1991 318i SOLD
                            2003 325i SOLD
                            Racecars and stuff.
                            • chadthestampede
                              • Jul 2008
                              • 3601
                              Yes I've always had luck with second gear. Also, not recommended, but I've actually done it alone (it's not easy on a flat surface).
                              Originally posted by LJ851
                              Feedback
