Fuel pump cutting out.
  • AlphaE
    • Sep 2011
    • 503
    also curious about this!! 88 supereta 2.7i for me to. Finally got the i AFM (was running the 88e afm) and now when u go on long left corner it cuts out. as soon as i come outta corner it runs strong again.. havent noticed it to the right yet. doesnt seem to related to fuel level. and i think it only showed up after puttin on the i afm. but then its only after puttin that on that been hitting the corners very hard. so maybe it was there before.... let me know what you find please.... could it be that the barn door afm meter is swinging shut? i have a kamotor CAI that not sitting perfectly level.. u have a AFM or MAF meter?
    Now with 2.7i power!!!
    • TheTacoMan
      • Nov 2011
      • 2308
      I have an Air density sensor with mega-squirt now, weird that you have the same problem. Ill keep you updated with what I find.
        Diagnostics would be the best way to approach this. Tee a pressure gauge into the fuel rail supply line and zip tie it to the cowl or a wiper arm. Then see what the fuel pressure does when an event occurs.
        • AlphaE
          • Sep 2011
          • 503
          i thought ur on MS. couldnt remember. gotta do some more spirited driving, long lefts and rights to see if there is any kind of regularity to it. But if urs does it w the speed denisity there goes my barn door closing idea.. it was far fetched i guess, figuring guys drive the mess these w/o the barn doors shutting them down..
          • AlphaE
            • Sep 2011
            • 503
            these cars have a oil pressure switch/sensor that cuts ign or something along those lines? its pretty common on lots of cars. wont start until there is oil pressure. m20's have that? i dont think they do..
              • 34844
              no, they do not.
              • series88
                • Nov 2011
                • 1231
                Check the connector of the fuel pump power. Most of the time they get cut and split because of how theyre angled. I went through 3 pumps already thinking that they died. On the third try, the new one never fired till i touched the connector. Thats when i saw the cuts.
                • series88
                  • Nov 2011
                  • 1231
                  Then it dawned on me to check all the pumps and yes, they all still work. And i got to think, the times they went out was after hitting a bump or turning quick.
                  • kamotors
                    • Nov 2007
                    • 7102
                    my guess is bad pump or bad wiring to the pump
                    7speedshop.com
                    • AlphaE
                      • Sep 2011
                      • 503
                      You get this figured out? I drove in circles a bit, but it didn't act up. Think I needed to go faster but some guy was already givin me the stink eye. Gotta find another parkin lot.
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        Bad wiring/bad pump
