Cluster woes, unsure where to part with my money
  • Andy348
    • Sep 2009
    • 688
    Upon my M20B25 swap into my 8/86 eta, I picked up 3-4 clusters from locals for very cheap and swapped out my 5.5K tach for a 7K one. Now that I've got the car running, I realize that the cluster has multiple problems:
    1) Speedo works only sometimes; it will die while driving and then sometimes come back on. The speed sensor in the diff looks good, and I hear it's rare that the speedo would just break so I'm leaning towards SI board cracks.
    2) Half of the backlights are out. I tried replacing the bulbs but to no avail - maybe I replaced the wrong bulbs, I'm not sure.
    3) Temp gauge occasionally screws up. Just yesterday I turned the car on (cold) and the temp gauge went right into the red and stayed there until I shut it off and started it again (returned to the blue). This leads me to believe SI board problems again.
    4) Tach sits at 0 at idle. Right now I think this is more related to vaccum leaks, which I will rule out next weekend.
    I have talked to GregM who offers great refurbishing services and found that a full look over and resoldering my SI board (and I think change the batteries) is $200. A new SI board from Blunt is ~$237 and then some money back for a core deposit. A used cluster can be found for $50-100, but once again I have no way to know if it works.
    Basically, is there a way to get a working, reliable cluster for under $150-$200? I'm on a very strict budget and would prefer to save as much as possible.
    If the original cluster didn't have these problems, swap in the 7k tachometer from another cluster.
    • dnguyen1963
      • Nov 2011
      • 2649
      New SI board from Programma is $169.00.
      • StereoInstaller1
        GAS
        • 22679
        First, get yourself a can of "electrical contact cleaner", a couple of pencil erasers and some good quality pipe cleaners.
        Clean every contact everywhere, the inside of the contacts of the plugs, between components on the cluster itself (like where the speedo plugs in) and anywhere you see any connections at all.
        You can swap parts to some extent, but there are minor compatibility issues in a few.
        GL, and what JLevie said is correct, just swap the tach over to your old cluster if it all worked good.
        Closing SOON!
        Thanks for 10 years of fun!
          • 34839
          you can get it rebuilt from a guy here, Greg or something, for probably less, and support the community at the same time.
          maybe he'll chime in, I apologize for not remembering his name.
          • agent
            Vice Grand Pubaa
            • 7960
            Gregs///M
            Originally posted by kronus
            • dnguyen1963
              • Nov 2011
              • 2649
              Greg///M has been contacted by OP. The cost for re-flow and new batteries is $200. I have not worked with Greg, but he sounds like an honest person. For a few more bucks, I would give the business to Greg///M. Programma costs $169, but then you have to add tax and shipping.
              • Gregs///M
                • Mar 2012
                • 2459
                Hey Andy,
                Send me the cluster, I'll give you a break on the price. Send me another PM when you are ready.
                Greg
                Owner - Bavarian Restoration
                BMW and European Electronics Repair and Restoration
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                Follow our Instagram!
                • Gregs///M
                  • Mar 2012
                  • 2459
                  I would say you have a combo of dead SI board batteries and solder joint cracks on the cluster main board. I also re-flow solder on the speedo assembly itself, which could also give you intermittent operation.
                  SI board only affects temp, mpg, tach and service gauges. Not speedo or odometer or gas. Those problems are probably cluster main board, gauge failure, or vehicle wiring.
                  www.BavRest.com
                  My Feedback Thread
                  Our Facebook!
                  • lowsodium
                    • Dec 2012
                    • 289
                    Pull the thing apart first and do a continuity test on the board. Takes like 20 minutes. I fixed a major issue on mine doing that. I just made a jumper cable to the two bad connections. Fixed all my lighting issues.
                    Haven't you ever seen Russian Nesting Dolls? They work like that.
                    1987 325e / 2008 135i
                    • e30construction
                      • Jan 2013
                      • 591
                      send it to greg..he fixed mine
                      93 325i 120k
                      mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
                      future mods: chip, m3 cams, headers, turbo
                      • Andy348
                        • Sep 2009
                        • 688
                        stupidly, when I moved I threw away three clusters apparently only good for parts. Really wish I would have kept them.
                        I'm going to go with Greg on this, but I'm definitely picking up some contact cleaner to clean the connections anyways. It can't hurt (unless I fuck it up of course)!
                        Originally posted by Gregs///M
                        Hey Andy,
                        Greg
                        Hi Greg,
                        Thanks for that, it means a lot. I will hit you up with a PM once I don't need my car as a DD, should be around May.
                        Seems like you're the man for the job. Also forgot to mention that the efficiency meter waves at me and is completely inaccurate.
                        Thanks for the advice everyone
                        • poopin04
                          • Jul 2010
                          • 1396
                          Did you figure out your issue? I'm having some of the some of the same issues. I'm thinking of giving it one last shot before I give up and send it to Greg.
                          Click here to leave me feedback on our transactions. :p
                          • EVillalonRN
                            • Jul 2011
                            • 386
                            Don't know if this applies with a full M20 swap, but for my i head swap I had to wire up the tach as seen in this page: http://www.strictlyeta.net/technical/328i_8.html
                            Hope that helps
                            My Transaction Feedback
