Everyone should buy a chip!
  • MitchFong
    • Sep 2005
    • 665
    Just installed my JC chip, what a difference!
    The throttle respsonse is amazing,mid power is greatly increased, my rough idle is now perfect. Couldnt be happier. ALso threw my new subs in and they rock also.
    Its a good day, and if your thinking about getting a chip, i highly reccomend it. Also, it is a very easy install, only bout 45minutes.
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    I was considering a MarkD chip but it seems a few peeps are having problems getting them delivered.
    Do they make a chip that is made specifically for an M20 with 19lb injectors using a stock AFM?
    • MitchFong
      • Sep 2005
      • 665
      i would assume the chip would work fine no matter what you have done to your motor. All it does is re-map the fuel injection, timing, gives you a 6900rpm rev limiter, and it must be used with 91 or greater octane gas. I strongly suggest you invest. Best investment for out motors IMO. Without doing a motor swap. Actually, i assume a cam would be a great investment to. But today was th ebest day of driving in my life. Throttle response was excellent. I didnt want to stop driving.
      • valleymotorwerks
        • Jul 2005
        • 174
        When you order your chip you will need to let him know what you've done...
        Valley Motorwerks
        1988 E30M3
        • wastedincome
          • Aug 2004
          • 906
          Who makes chips for the M42??? Anyone here using one??
          The M42's require 91 octane stock so I figure a Chip wont require anything more then the $$ for purchase
          Wastedincome420@yahoo.com
          CURRENT STOCK LIST:
          00' e38 750iL HighLine=Highway Queen
          92' e30 318 vert=Aint going anywhere
          91' e34 535iM=Aint going anywhere
          91' e34 525iA=For parts
          92' e34 535iA=For parts
          • MitchFong
            • Sep 2005
            • 665
            Im pretty sure the manual recommends you use 91 on all motors.
            I was using premium before i bought the chip, so its only an extra 7 bucks per fill for a lott more fun. The car seems a lot healthier to.
              • 34839
              nope, what it says is to use unleaded fuel only.. no reason to use 91 octane on a stock M20 with 8.8:1 compression, or a low revving eta.
              • MitchFong
                • Sep 2005
                • 665
                on an eta, yes. But i use 89 or 91 in all my cars/skidoos/dirtbikes/etc. Just better gas.
                But yes, you are right. I just looked through the manual then. The car definately would rahter have 91 octane in it tho:)
                • Jordan
                  • 12913
                  Now that is entirely dependant on driving style and climate.
                  Here in TX its hot. Kristin has to run 91 or 93 or here bone stock m20b25 pings.
                  EVERYTHING here in Texas pings on 87. All day long I listen to otherwise boring plain stock cars, new and old, of all makes and models.. drive by at part throttle, pinging so loudly/freqently on every cylinder it completely drowns out any exhaust note.
                  https://mtechniqueabs.com/
                  • Jand3rson
                    • 37587
                    Try installing a JimC chip on an eta. The difference is mind-blowing. :D
                    As far as octane ratings go, my wife's 325i will run like SHIT on anything less than at least 89 (plus). On regular, it runs like shit and pings a lot. The elevation here has a lot of adverse side effects. When Jordan would come up here in the E36 M3, I swear it would loose like 20-30hp, it felt like there was 5 more people in the car.
                    • cpain49176
                      • May 2005
                      • 102
                      flame if you want, but i just got a chip off of ebay for 30 dollars. the difference in performance is incredible, esp. in the upper rpms. might not be as good as a JC chip, but at least it wanst $250.
                      as for octane, my car runs ruff on anything that isnt 93.
                      • MitchFong
                        • Sep 2005
                        • 665
                        i just dont trust ebay. Someone prolly made that thing in their basement, your cars gunna blow up in a few weeks.
                        .. J/K, i got mine used for a good price. I just havnt heard any good things about the ebay chips.
                        • cpain49176
                          • May 2005
                          • 102
                          yeah, theres a lot of shitty products on ebay, but there's a few good ones too
                          so far so good, if it shits out, oh well it was only 30 dollars
                          • silversleeper
                            • Mar 2005
                            • 2032
                            So what exactly is involved in programming chips? Special equipment? Software? How are they tested and so forth?
                            Claus Luthe is my hero.
                            • RobertK
                              • Jun 2005
                              • 5864
                              A 486 IBM Compatible computer with an EPROM serial programmer, DOS, and a floppy containing the program you need to read/write your program to the chip.
                              I have a good friend that programs all kinds of EPROMs to hack different kinds of electronics. He owns an electronic repair shop close by and has the equipment to copy most any type of chip. Of course he doesn't know jack shit about cars so programming custom chips is outta the question.. BUT if anyone wanted to copy a chip I'm sure he could do it.
