Speedo Connectors
    Alright guys, I checked the fuses, they are all updated to non-german fuses. Problem proceeded. Then, I took the speedo out of the car and reflowed all of the solder joints. Problem seems fixed! Going on 4 days of a working speedo. Aaaaand, my temp gauge works, it didn't before. But the only problem I have now is the fuel gauge quit working. Story of my life.
    @Victor,
    I had the same problem with my 325e. I think it ended up being that someone replaced one of my relays with a non-bmw relay. I checked the schematic and wired the relay correctly. I think it was one of the bypass relays up in front of the strut tower.
    1984 325e
    2000 323i
      Originally posted by dogsbark26 View Post
      My experience with intermittent speedometer operation...
      Sent cluster to North Hollywood Speedometer at 6111 Lankershim Blvd., North Hollywood California 91606 USA with instructions that speedometer was intermittent. They replaced main board. Charged me about $125.00. I installed. No change. Speedometer still intermittent.
      Complained to North Hollywood Speedometer. They said "send it back and we'll replace speedometer circuit board for another $125.00." I said, "FAT CHANCE!"
      I then replaced speedometer with one from a different cluster. Now works fine.
      Most of these companies just have a troubleshooting chart with some rookie reading it. Whatever the symptoms are, they just replace what the "chart" tells them to. They literally just throw parts at it until it works.
      I literally test the speedometer in place on my work bench so I know exactly what is wrong with it. If you guys still continue to have problems with your speedo's, let me know and I can fix it for much lower rates than these "speedometer" companies.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
        Cool beans Greg. I didn't know that was one of the services you offered.
          Thanks Greg! Can you check all of the other components as well? Such as fuel, tach, temp?
          1984 325e
          2000 323i
            I've already completely restored several clusters for members here. Every gauge is checked. All solder is re-flown with new solder, SI board is repaired and batteries replaced, high speed polish on front cover, new odometer gears, red needles, it will work like brand new again. Fully tested and documented.
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
              Which thread is the pricing for those services please?
                No threads on cluster repair yet. Just send me a PM and we can talk pricing. I'll be releasing a thread to the public once my official cluster tester is done.
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
