Speedo Connectors
  • e^2
    • Dec 2010
    • 65
    Speedo Connectors
    I thought I would post this, as I'm having troubles finding anything on the cluster connectors online. I found some similar parts that show how the sockets and connector look when they're new.
    Connector
    http://uk.farnell.com/jsp/search/pro...ote-8180016-pr
    Sockets
    http://uk.farnell.com/te-connectivit...imp/dp/8180121
    I happen to have two sockets that have been mashed by someone. I have an intermittent speedo that comes on and off with bumps and dash pounds. Sigh. New SI board, new main board, and it is coming down to this. Anyone else had this problem?
    1984 325e
    2000 323i
  • mitchlevy7
    • Aug 2011
    • 672
    i think i have all the pigtails for the cluster connections. pm me if you want them.
    www.cp-e.com
    1989 Zinno 325i m52 turbo coupe
    2015 Ford Fiesta ST, Daily Driver.
    • e^2
      • Dec 2010
      • 65
      Do you have the loose parts? I just need the pins. These pins do NOT come out nicely without the tool so I don't think just the pigtail works well for my situation.
      1984 325e
      2000 323i
      • e^2
        • Dec 2010
        • 65
        Ya, Iyanked out the pin (destroyed it in the process) and replaced the bad pin with a wire I mashed in the socket. Speedo works great. So now I need a new pin.
        1984 325e
        2000 323i
        • Gregs///M
          • Mar 2012
          • 2459
          Forget the sockets, you need the proper crimper for those. I have this crimper and it cost about $150.
          You should be able to get by with just crimping with needle nose pliers then following with soldering it.
          Owner - Bavarian Restoration
          BMW and European Electronics Repair and Restoration
          www.BavRest.com
          My Feedback Thread
          Our Facebook!
          Follow our Instagram!
          • e^2
            • Dec 2010
            • 65
            So what I didn't notice was a TPA lock on the side of the connector. Pulled it out and now the pins come out smoothly. So I got a connector for spare pins, replaced the pin I damaged, and tightened up the rest of the pins by gently squeezing them with some pliers. Unfortunately, my speedo still works intermittently. Guess I hadn't fixed the problem. Does anyone have an idea that would cause an intermittent speedo? I have a new SI board, a clean main board, and clean contacts.
            1984 325e
            2000 323i
            • Northern
              I like cupcakes & sh!tboxes
              • 5264
              Speed sensor connector at the diff. Or the pigtail.
              Originally posted by priapism
              Originally posted by shameson
                Right. The connector at the differential, cracked solder joints on the main PCB in the cluster, cracked solder joints in the speedometer, bad cluster ground, or wiring problems are all possibilities.
                • e^2
                  • Dec 2010
                  • 65
                  Alright, I tightened up the connectors at the sensor, the ground at the speedo is good and clean. I'll test drive and if it still isn't working, then I'll reflow the joints in the speedo and check the traces on the main board.
                  1984 325e
                  2000 323i
                  • e^2
                    • Dec 2010
                    • 65
                    Hmm, speedo worked straight away after the sensor contact tightening. Thanks for the pointers! We'll see how it behaves this week.
                    1984 325e
                    2000 323i
                    • e^2
                      • Dec 2010
                      • 65
                      Ya that didn't last long. It's back to not working. I'll try to verify a signal at the speedo but man is this getting old. There really isn't too much that could go wrong, why is this so difficult?
                      1984 325e
                      2000 323i
                      • Gregs///M
                        • Mar 2012
                        • 2459
                        Replace fuse 10, 12, and 21. Those power the cluster. Replace them.
                        www.BavRest.com
                        My Feedback Thread
                        Our Facebook!
                        • Victor_PR
                          • Jun 2011
                          • 296
                          Hi;
                          I replaced these 3 fuses yesterday as mi speedo also works intermittently. When I removed fuse 21, I got a small spark at the fuse female connector at the fuse box. I replaced with new fuse and noticed that my radio would not turn on. I looked closely at the 3 fuses I had just replaced and noticed that Fuse 12 was broken. Replaced and all OK.
                          Now: Not sure if related but I am noting a harder start when car is warm. I know I have a leak at my ICV - a replacement is on its way - but I didn't have that much trouble starting before yesterday.
                          Any thoughts?
                          Victor
                          Rides...
                          E30 325i - 1990
                          F30 328i - 2014 (DD)
                          F25 X3 - 2016 (Family car)
                          1974 - 2002 (The ruler of the stable) SOLD
                          • dogsbark26
                            • Nov 2008
                            • 533
                            My experience with intermittent speedometer operation...
                            Sent cluster to North Hollywood Speedometer at 6111 Lankershim Blvd., North Hollywood California 91606 USA with instructions that speedometer was intermittent. They replaced main board. Charged me about $125.00. I installed. No change. Speedometer still intermittent.
                            Complained to North Hollywood Speedometer. They said "send it back and we'll replace speedometer circuit board for another $125.00." I said, "FAT CHANCE!"
                            I then replaced speedometer with one from a different cluster. Now works fine.
                            • Quadrajet
                              • Jul 2008
                              • 1278
                              Intermittent speedo issue is what brought me to retiring my 84 325e, I got tired of constantly pulling the cluster to check this or try that, by then I had my M42 car running.
