all my gauges went out.
    everything stopped working instead of the speedo. is this a fuse that has gone out?
    1984 Eta
    1987 Bagged
    1988 I
    1995 MX5
    1998 C70T5M
    2002 CL600
    The fuses would be the first thing to check.
      definitely the fuse, had the same thing happen to me.
      I like cats.
        Fuse 10, 12, 21, all 7.5A. Just change them all.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
          ill try that
          1984 Eta
          1987 Bagged
          1988 I
          1995 MX5
          1998 C70T5M
          2002 CL600
            update- replaced the fuses with 10 amp. started the car like usual with everything working. as i start moving fuse blows and everything goes back the way it was.
            any suggestion on where i should start my search for a short?
            1984 Eta
            1987 Bagged
            1988 I
            1995 MX5
            1998 C70T5M
            2002 CL600
              Using the wiring diagrams from http://wedophones.com/BMWManualsLead.htm, start trouble shooting the circuit that fuse feeds.
                thanks man
                1984 Eta
                1987 Bagged
                1988 I
                1995 MX5
                1998 C70T5M
                2002 CL600
                  Edit
                  - AXIS POWERS - 2JZ E30 Build
                  Current Project - 87 325is 2JZ Swapped with M4 DCT
                    checked the wires coming from the shift hole, one was slightly stripped and shorting out. taped it up replaced the fuse and hasnt happened again
                    1984 Eta
                    1987 Bagged
                    1988 I
                    1995 MX5
                    1998 C70T5M
                    2002 CL600
