Help finding part - First Aid Kit, Tidy Tray hold down "bolt"
  • ivangene
    • May 2013
    • 41
    seems there should be a push plug or bolt type thing going through the bottom of the tidy tray into the top of that battery cover - there is about a 1/2 in hole that lines up well in both
    but what goes in there
    as much as I love this "kit" every time I get the azz to hang out a little, the whole damn thing flies around the trunk - something MUST hold this in place
    post a link if you know where to find it and THANKS!!
  • e30jake
    • Feb 2012
    • 855
    Sub'd. I have the exact same problem
    What it feels like owning an e30:
    88 325 S50 swap in progress
    90 325ix
    • ivangene
      • May 2013
      • 41
      found a pic of the case showing the hole in the bottom
      • JonnyOg
        • Sep 2012
        • 191
        Why not just drill through your battery cover and run a nut and bolt through the hole?
        • Northern
          I like cupcakes & sh!tboxes
          • 5240
          I had never even noticed that there was a hole there.
          Originally posted by priapism
          Originally posted by shameson
          • ivangene
            • May 2013
            • 41
            Sure there are ways to keep it in place, and Home Depot has lots of them,...but I figured there must be a part missing...maybe costs $3, and would be the "right fix"
            Heck, I thought of a bungee cord....but then saw those holes and see they line up....something said, hey....I wonder
            I may swing by BMW on my way home and see if they have a microfiche showing a part???
            • ELVA164
              • 4861
              Originally posted by JonnyOg
              Why not just drill through your battery and run a bolt through the hole?
              Good idea, +1.
              I agree to try the dealership, at least they could tell you if it's worth the search or not.
              • Chuck C
                • 104
                That trunk tray has been NLA for a long time--the part number is no longer in BMW's database.
