Throttle Body Coolant Housing
  • mcaden
    • Jun 2011
    • 164
    I recently noticed just the slightest weep of moisture (blue coolant) at the throttle body coolant housing with no noticeable loss of coolant. Notwithstanding, I think I will just go ahead and replace the gasket to prevent a future failure (replacing gasket and new bolts).
    Do I need to remove the throttle body to do the job or can I leave the throttle body in place? I will use PB blaster on the bolts in the hopes they come out cleanly. Also, anyone know the torque spec off hand for the bolts (if not, I can look up later in my Bentley).
    Thanks,
    Marc
    The gasket can be replaced w/o removing the throttle body. Replace the hoses at the same time.
    • mcaden
      • Jun 2011
      • 164
      Thanks Jim - I was hoping not to remove the throttle body, but not a big deal either way.
      • FLG
        • Sep 2011
        • 3165
        Also if you needed a quick fix, you could tap the hoses together and by pass the heater.
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • TobyB
          • 5280
          three times, spin around, and chant 'there's no place like home?'
          hee
          t
          • MNE30
            • Jan 2013
            • 79
            If you do tape the hoses together can I expect the TB to ice up? (Sorry for using this thread to answer my questions, but i've got the same issue...)
            Mine drips quite a bit when the engine runs and it's annoying the hell out of me and getting air in to my coolant system...
            • FLG
              • Sep 2011
              • 3165
              Lol Toby!
              I've never heard anyone with an issue with it freezing up.
              Sent from my Galaxy Nexus using Tapatalk 2
