Front jackstand placement
  • J3M93
    • 448
    Another one of my newb question threads
    so i'm about to replace the front suspension and was having some trouble placing the jack stands, the type of stands that i have are these
    I know that i should put them under the frame rails behind where the control arm bushing bolts to, but the top of the jackstands are not wide enough, such that the frame rail will be resting just on the upturned edges of the jack stand.
    Would this be safe or should i consider other locations for the jack stands?
  • JWS45
    • Mar 2013
    • 43
    Check this out:
    I would recommend the alternate front end jackstand jacking point...
    - 1991 325i Sterling Silver Coupe
    - 2010 Mitsubishi Evolution X SE
    • oliver.r
      • Mar 2012
      • 3839
      if you have a grinder just flatten out the areas that bend up?
        You can place a block of wood between the stands and the frame rails.
        • Cletonius
          • 2809
          You can put stands on the pinch weld as long as it's not rusty where it would cave in
          - Josh
          1990 325is
          Need a shift boot?
          Looking to buy shift boot frames, PM if you have one to sell
          Here's what happens when you let the internet pick your license plate
          • 36brua
            • 689
            This is what I did. you only need 5/8" thick or so to be above upturned ends. Cut plywood rectangles, and if anal like me, you can shape bottom of wood to match metal base for full support. Then use the obligatory duct tape to secure to jack stand.
            My CA legal M60 swap
            The happening in our garage
            • TobyB
              • 5297
              if you like crushing the pinch weld...
              t
              • Cletonius
                • 2809
                t
                My car stood on stands for 6 weeks while I replaced my suspension and the pinch didn't deform in any way. If it's not rusty it will easily hold the weight of the car.
                - Josh
                1990 325is
                Need a shift boot?
                • pandaboo911
                  • 2070
                  Put em under the frame rails.
                  Or get those rubber jack stand covers that have a nice groove in them to allow you to set them under the pinch weld without bending it up
                  • J3M93
                    • 448
                    thanks for all the replies, i'm going to chuck them under the frame rails with a shaped piece of wood, i know that the pinch weld jack point shouldn't bend but it's pretty far back so i'm concerned with the amount of weight that would be forward of it so im not going to go that route.
                    • 36brua
                      • 689
                      I use stand /wood-- front frame rails and rear sub frame mount. add a pad to your floor jack plate so you don't tear up the undercoating. set stands,
                      step back and give car a stability shake. It doesn't hurt to leave the jack someplace under the car for secondary safety.
                      • Cephas
                        • Apr 2012
                        • 878
                        I always leave the jack about 1/4 inch below the frame rail on whatever side I'm working on. Nothing wrong with a little added safety!
                        • DIIRTY-30
                          • 1665
                          My pinch weld looks like a waffleswaffleswaffleswafflesed up piece of bacon because one of the PO used it too liberally.
                          BLUE NOSE - M62 SWAP
                          THE E30 + 1 BUILD
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            You know, if you use a soft wood it will pretty much shape itself once the weight of the car is on it. Just remember to heed the direction of the grain or it's quite possible to split a block on the first try.
