Just purchased 88 325i convt, AT. Speedo works, but odometer and trip don't. where should I start? Also, oil light flickers at idle, goes away when accelerating-has oil in it and seems to have oil press. Is there an oil pressure switch I should start with? thanks
odometer inop
The odometer gears failing is very common on E30's. You can buy new ones from member Garagistic on this forum, best quality and price around. The oil pressure switch is located on the side of the engine block, passenger side. Check wiring at connector and replace switch if problem continues.Owner - Bavarian Restoration
BMW and European Electronics Repair and Restoration
www.BavRest.com
My Feedback Thread
Our Facebook!
Follow our Instagram!
this is the definitive DIY manual for e30s:
http://www.amazon.com/BMW-Series-E30...ds=e30+bentley
The bentley combined with google/forum searches of the specific problem you are having (and related DIY articles) should guide you through most repairs assuming you have the tools.Comment
This is by far our most asked question. So how do you know what unit is in your E30? Well, here are a couple of ways you can tell. The first way: Stamping on the face of gauge cluster Your E30 3 series or M3 will have the either "VDO" or "Motometer" stamped in the gauge cluster between the RPM and speedometer. This i
This guide should only be used to help you as a suggested way to fix your equipment. They are not intended to be the only way to do. Its your responsibility if any damage occurs. If you are not sure of any part of these instructions, feel free to send us an email, we would be happy to help. There are many small pieces
