E30 Instrument cluster not working.
  • lcc9115
    • Aug 2012
    • 26
    I'm sure this has been brought up before but I am getting different answers from people so just want to clear it up. The car is a 1993 E30 325i vert.
    A few months ago my Tachometer stopped working. Started to jump then cut out completely. Recently my Speedometer started to cut off when I let off the gas and come back when I hit the gas. Now is basically stopped working completely only coming back up when I am on the gas.
    I read that the batteries on my SI board are dead but a mechanic told me I need to replace the entire instrument cluster. I can probably replace the SI board myself but not the cluster. Big cost difference.
    Any thoughts/experience with this? It's tough to drive with the instruments starring me in the face not working.
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    Take your SI board to batteries plus and have them solder new batteries in it.
    Yours truly,
    Rich
    you kids get off my lawn.....
    • Gregs///M
      • Mar 2012
      • 2459
      I would start by replacing the fuses for your cluster. They are fuse 10, 12, and 21 all 7.5A. Don't check them, just replace them.
      If that does not work, I would go ahead and proceed with replacing your SI board batteries. Also check the connector at the rear differential. That is the speed sensor connector and it is well known to get dirty, corroded, and loose. Clean it up, and tighten up the connection and your speedometer might start working again.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • saturnv7890
        • Jan 2011
        • 696
        It also takes 25 mins tops to pop out the cluster and tighten the ground nuts on the back, but I'd do that after the fuses and when you're ready to test those SI batts
        My Transaction Feedback
        My "build" thread
        BUY MY CAR!!
        • Jdesign
          • Jun 2012
          • 198
          Awesome!! I have a 93 325 vert with the same issues starting to brew.
          • lcc9115
            • Aug 2012
            • 26
            Thanks, I'll try to fuses and go about replacing the batteries. The mechanic I've been using said the batteries have nothing to do with the tach/speedo but too many people tell me otherwise.
            • dnguyen1963
              • Nov 2011
              • 2649
              Your mechanic does not know how BMW works.
              • Gregs///M
                • Mar 2012
                • 2459
                +1 on your mechanic not truly familiar with BMW cars, especially electronics.
                www.BavRest.com
                My Feedback Thread
                Our Facebook!
                • 2761377
                  • Jan 2011
                  • 398
                  trying to meet that 25 minute deadline is a good way for a noob to break both tabs off the cluster.
                  noob, give your self 3 hours and just get the si batteries replaced while the cluster is out.
                  hth
                  robert w.
