Fan shroud: is it necessary?
  • thatphysicsguy
    • Mar 2013
    • 843
    My fan shroud is warped and interfering with the fan. I'm gonna try to fix it and put it back on eventually, but I'll be running without it for a few days.
    Is this a bad idea? does the an shroud help airflow a lot or is it just mainly for cosmetics/safety?
    (M20b25 if it helps)
    '91 325i
  • ak-
    • 12422
    Yes it helps concentrate air to the rad.
    You'll be fine without one permanently, but it's just more efficient with one.
    1991 325iS turbo
    • thatphysicsguy
      • Mar 2013
      • 843
      Ok so I should be good for a couple days while I mod it.
      Thanks
      '91 325i
      • ak-
        • 12422
        I haven't had one for half a year telling myself I'll put it back on (when I find out where I put it lol).
        You're going isn't going to over heat. No worries.
        1991 325iS turbo
          • 37833
          It's most effective during stop & go or drive through scenarios.
          They are only about $20 new so it may be worth buying a new one.
          Grover Beach, California
          BimmerHeads.com
            • 34847
            it'll be fine for a few days. I haven't had one for years.
            • poopin04
              • Jul 2010
              • 1396
              Well shyte, I guess I should purchase on. I haven't had on in 4 yrs, Hell I didn't realize E30s came with one. But I do get stuck in alot of stop & go traffic in the city.
              Click here to leave me feedback on our transactions. :p
              • Exodus_2pt0
                • 5943
                Always ran my e30's without a shroud or fan. Just made sure the condenser fan worked and it was always sufficient.
                That said, I don't drive in stop and go on 100* days either.
                No E30 Club
                • peytonracer4
                  • May 2011
                  • 524
                  how is it warped? is it at the bottom in the middle? if so, this is normal. there's an attachment point there. you'll see a little hole at the bottom of the shroud that matches a little hole in the radiator. just run a zip tie through there.
                  i had this happen to me recently and i overheated because the fan wouldn't move :(
                  • thatphysicsguy
                    • Mar 2013
                    • 843
                    Yeah I'm gonna run some wire through it, but it can wait for another day
                    '91 325i
