tick tock tick tock?
  • nunezfrancisco30
    • Mar 2013
    • 94
    Is it bad when your fuel pump has a fast tick to it? With the ignition in the on position without cranking it, I can hear the fuel pump ticking really fast. Im hoping that its not something serious.
    The pump is controlled by the DME and should only be on when the DME sees timing data from a rotating engine, so it should not be making noise with just the ignition on. Perhaps what you are hearing is from something else?
    • crazyman
      • Dec 2010
      • 738
      ^what he said exactly^
      Your probably hearing a faulty relay kicking on and off. That's where I'd start looking imop.
      85 swartz/metallic 325E
      84 alpine 325E
      85 zinnoberot 318i/R.I.P
      84 Bronzit 318i/sold
      purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
      • TobyB
        • 5297
        IAC???
        t
