85 eta to latemodel c104 Glovebox ECU connector options
  • kamotors
    • Nov 2007
    • 7102
    So I'm doing another 327i turbo build this time the ECU 3 pin connector isnt compatible with the body harness. Anyone have a diagram of which wires connect to which or what I need t do to get the car running?
    7speedshop.com
  • kamotors
    • Nov 2007
    • 7102
    can anyone confirm that this will work?
    Pin 3 from c104 to pin 8 on the c101 of the 89(yellow/white or white/white wire)
    Pin 2 from c104, run a wire directly to the + terminal on the coil (green wire)
    Pin 1 from c104 to pin 9 on the c101(black wire)
    7speedshop.com
    • kid325e
      • Sep 2007
      • 6422
      What I did was take the C104 Connector from the engine harness from the Eta and splice it into the 325i Engine Harness. I used this as a reference.
      Let me know if you want me to go take a pic of my current setup. I've been meaning to a good writeup. It's pretty straight forward with both harnesses in front of you.
      clutchCTRL!
      Move with a purpose.
      - 1991 325iX 4dr/5spd
      - 2000 323i AT
      2016 Mazda CX3 Sport AWD
      • kamotors
        • Nov 2007
        • 7102
        Just wanted to update that all you need to do it wire pin 2 on the c104 to the Coil and the car will fire right up:)
        7speedshop.com
        • TobyB
          • 5297
          And make sure that pin 20 on C101 isn't hooking a red to a green...
          t
          • kamotors
            • Nov 2007
            • 7102
            its wired like this, car starts and runs, no pin 20.
            7speedshop.com
