Smoke tester questions
  • LateFan
    • May 2013
    • 4436
    I would like to build a smoke tester similar to this...
    Question -
    I have no compressor. At only 2 psi, is it possible to just blow on a hose into the smoke can? Or can you not maintain the pressure long enough to test?
    What about a fitting on a bike pump?
    Thanks -
  • SmokeE30
    • 1730
    You could probably rig up a air tank to work if you have one of those, maybe even a tire with the schrader valve removed might work. But having it done by a shop with the proper equipment would probably be your best bet
    Shawn @ Bimmerbuddies
    Bimmerbuddies LLC
    717-388-1256
    2971a Roundtop Rd, Middletown PA 17057
    bimmerbuddiesllc@gmail.com
    • efficient
      • Feb 2012
      • 3312
      • LateFan
        • May 2013
        • 4436
        Hah! I thought he said "...talkin' rice, boys.."
          You will need to hold pressure on the engine for at least 5 minutes. So trying to puff into the system is gonna be difficult.
          • LateFan
            • May 2013
            • 4436
            Right.
            So does a bike pump send plenty of pressure on downstroke, then zero? Or does it hold the pressure, like when you pump a road bike tire to 110psi? It holds pressure between pumps.
            • Boostesi
              • May 2011
              • 220
              Originally posted by LateFan
              Right.
              the schrader valve on your tire is what hold the pressure between pumps.
              sigpicFellow e30 enthusiast
              Dont waste your time hating, aint nobody got time fo dat
              1986 bronzit 325es- SOLD
              1987 delphin 325i- parts car
              1990 scwarz 325is- m50 drift slut
              CHECK OUT THE BUILD!
              http://www.r3vlimited.com/board/showthread.php?t=229234
              • LateFan
                • May 2013
                • 4436
                Ohh yes...or the Presta!
                Thanks.
                • offsetmotorwerks
                  • Apr 2013
                  • 27
                  http://www.chevytalk.org/fusionbb/sh...hp?tid/223962/
                  • LateFan
                    • May 2013
                    • 4436
                    2 psi aquarium air pump?
                    5 gal Harbor Freight 125 psi air tank?
                    Harbor Freight super cheap 12V inflator / compressor?
                    Cheap compressor that won't work for any real air tools I would need?
                    Spare tire with a hose and pressure regulator?
                    • glnr13
                      • 1334
                      more effort to make one than to just take it to your local mechanic and test it in 5-10 mins.
                      • LateFan
                        • May 2013
                        • 4436
                        Yeah.
                        But I like the idea of making one and fiddling with different cars.
                        • offsetmotorwerks
                          • Apr 2013
                          • 27
                          Just showing it is pretty easy to make a cheap one, I wouldn't use their exact formula...
                          • glnr13
                            • 1334
                            you'll need a compressor to build a good smoke tester.
                            using a bike pump and a shrader valve is not fiddling, that's mickey mousing it IMO
                            but if you must, you could do it with one of those fix a flat compressor things.
                            • LateFan
                              • May 2013
                              • 4436
                              Did some more reading. Sounds like 2psi isn't really ideal - maybe more like 5 to 10. And enough cfm to move it through the system.
