I know this looks like a novel but I just have to explain my process.
So I replaced my starter the other day so I drained my whole cooling system so I could move the heater core hoses out of the way. So When I got it started and stuff I put the car on a the slanted driveway facing up hill and unscrewed the bleed screw on top of the thermostat housing. So the car started to just stream air while engine temperature was sitting just a bit above half and then kept streaming air... and kept streaming air... and kept going. About five minutes later not a drop came out of the damn bleed screw and the reservoir was full of water as well. So I kept the bleed screw unscrewed slightly and drove 3 or 4 blocks and pulled over, popped the hood, checked the screw and water was spilling out with bubbles and stuff. Then after about 30 seconds of idle the damn thing kept streaming air! I also noticed that when I drive the temperature creeps up, and I have no heat inside the car. I'm 99% positive I put the heater core hoses back on in the same manner they were in before. I know the temperature switch works because I can hear the difference in air speed through the fan when I switch it from hot to cold and cold to hot. I have no idea what is wrong so I need someone to help me out!
