In what fashion do you remove the head?
  • noid
    • 1537
    Interested to hear how you guys remove the head when doing a headgasket or similar, seems like everyone has their preference.
    Do you:
    Remove the intake manifold and exhaust manifold and then take head off?
    Take head off with intake manifold and exhaust manifold still attached?
    Take only the intake manifold off and keep the exhaust manifold on?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    • 34844
    It will be really heavy with the manifolds attached..
    • reelizmpro
      • 9552
      If you leave the manifolds on they can be used to pry the head loose without damaging the head. Once removed, the manifolds are much easier to remove too.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • SmokeE30
        • 1730
        I leave the manifolds on for removal I've found although its heavier it makes things easier to pull apart once off the car
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
          Having a hoist handy, I remove or install the head with the intake and exhaust attached.
          • noid
            • 1537
            When pulling a head of an early harnessed car with that does not have a detachable fuel injector connector rail, does one just pull each connector through the back after removing the AFM/Throttle body assembly?
