Motorized Rear Coupe Windows
  • McGyver
    • 4637
    I know that I've seen a thread about installing motorized rear coupe windows, but I didn't find it and don't feel like looking too hard. Basically I can't reach the mechanism to open/latch shut the rear windows when I'm driving. You know, start on a long drive an the wind noise is too much at 80+ on the highway. Or want to have them open but know that it may rain, and then it does.
    Here's my train of thought, and tell me if I'm crazy:
    1) Take the power from the battery in the trunk and for a SPST relay with an inline fuse
    2)this allows power to the 12V switched wire in the auxiliary fuse box
    3)12V switched goes through the window button to an opener from a van/newer BMW
    4)fabricate a bracket so opener screws to the stock holes
    5)do something so the opener doesn't look janky
    Has this been done before? Any pictures or insight?
  • SlamedIAm
    • May 2011
    • 318
    I believe I've seen this on an E36 coupe, possible a Euro option? Might be a good place to start.
    • TobyB
      • 5280
      Dodge minivan...
      t
      • AndrewBird
        The Mad Scientist
        • 11898
        Convert to non-popout windows. Problem solved.
        Either that or accelerate up to about 100mph. They will slam shut at that speed.
        • bmwstephen
          • 2463
          It's been attempted. And last I saw someone, on s14.net was able to do it because of the M3's larger C pillar. However, it still wasn't pretty...
          As NitroRustlerDriver mentioned, convert to non-popouts
          • McGyver
            • 4637
            Well, I actually converted my solid state windows to popouts. I like the air flow and the look.
            So I guess I'm gonna do it and I'll let you guys know how it works out.
            • Andy.B
              • Sep 2011
              • 1650
              This is something I've thought about, and am amazed that there if nothing readily available from the typical aftermarket sources. I have seen people retrofit the pieces from later BMW coupes, but the parts are either expensive new, or hard to come by used.
              I have thought about scavenging parts from a van, but haven't taken the time to track down the parts.
