ZF4HP22 weight?
  • 2.5-12
    • Jan 2010
    • 1814
    ZF4HP22 weight?
    I have an automatic trans I need to ship but its in the car still and I need to get quotes.
    does anyone know how much a ZF4HP22 weighs with or without a torque converter installed?
    Thanks.
    1991 E30 M3 Brilliant/black - S54B32/5M
    1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
    2011 E82 1M VO/blk/6M
    1991 E31 850i red/grey/6M
    1997 F355 spider red/tan/6M
  • DEV0 E30
    • Oct 2004
    • 8904
    150-175lbs I found googling around, it was used in many cars.
    I would get a quote for 200, package it like your life depends on it, and insure the hell out of it.
    • 2.5-12
      • Jan 2010
      • 1814
      ground has a max of 150lbs, hoping its under 150 without tq converter
      not worried about packaging it, but freight is a lot more expensive
      • 2.5-12
        • Jan 2010
        • 1814
        looks like a 4hp24 sans converter is 125, so that should be about the same right? same case and pan..?
        • jeffnhiscars
          • Jun 2011
          • 6011
          I just pulled one out of my trunk the other day and while I had help I think 125 without the TC would be a safe estimated. The TC is probably another 30.
          Alice the Time Capsule
          • 2.5-12
            • Jan 2010
            • 1814
            excellent, thanks for that info sir :)
            • golde30
              • 11464
              damn heavy. getrag 260 weighs in just under 80lbs.
              IG: @Baye30
              • 2.5-12
                • Jan 2010
                • 1814
                I know exactly what a dry G260 weighs, I ship those all the time -- this is the first automatic which is why I'm specifically asking for ZF4HP22 weight.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  This thread says it has a dry weight of almost 80kg. If you dont speak metric thats 176 lbs
                  mines, mining, mine, cumbria, slate, lead, iron, zinc, industrial archaeology, exploration, srt, underground, speleology, caving, vans, van, sherpa, leyland daf, ldv, land rover, landrover, v8, rover v8, efi, lpg, 4x4, acorn, riscpc, vehicles, cars, montego, montegos, rover, mpg, opinions
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    he must mean with converter? I was able to lift it off of my trans jack pretty easily after removing it yesterday.
                    will weigh it before it goes out and post up for future people needing to know
                    that LandRover 4Hp22 has a more substantial bellhousing than the E30, the pan is a bit different too, that may make up some of the differences
                    • jeffnhiscars
                      • Jun 2011
                      • 6011
                      Correct. I believe thats the complete unit
                      • 2.5-12
                        • Jan 2010
                        • 1814
                        ok, verdict in:
                        ZF4HP22 bone stock with flex disc, pan and bellhousing. fluid drained.. 108lbs
                        torque converter
                        31lbs
                        total shipped weight in a tub with some mild reinforcement was 149.80lbs.
                        .19lbs under the limit of Ground shipping.
