Asc+t
  • MrK
    • Jan 2006
    • 709
    Asc+t
    I'm not quite sure which subforum this belongs in, so I apologize in advance if there was some better place to post.
    Anyone tried retrofitting ASC+T into an e30? I'm tired of slowing down in the rain...
    I know that 'anything' is possible if you throw enough money at it, but I'd like to know what kinda money we talkin about.
    This is your M20 on steroids:
  • Brew
    • 3060
    Can't see how you could make it work without swapping over tons of control units and speed sensors from an e34 or e36.
    You would be much better off with an aftermarket traction control system, like Racelogic. Then again, I wouldn't even think of spending the money on traction control unless I had uncontrollable wheelspin at highway speeds in the dry.
    '91 318is
    • SpecM
      • Oct 2005
      • 4531
      -Eh, you already have ABS, so trac. is just a matter of wiring and comuter work. Maybe rig you ABS modual to dab the brakes when need be?
      -Anyone know it e30 ABS is one chanal, two chanal, or four-chanal? (<-I know, I spelled "chanal" wrong...)
      1989 cirrisblau-metallic 325i
      • PeaveyBassist
        • Sep 2004
        • 3511
        All traction control does is cut the throttle when it detects wheel slip. It will slow you down just as much as you slow yourself down in the rain. You need to slow down in the rain anyways so why spend the money getting traction control in a 15 year old car?
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • 34844
          a better and cheaper way would be to learn how to drive your car. spend money on Autox's and DE's instead of a "hold my hand so I don't screw up" mod. you'll be a much better driver and will be safer than having no clue with traction control to take care of your mistakes.
          and if you get a chance to autox in the rain, do it! it's a very safe place to learn your limits in the wet, so you'll have an idea of how much to back off when it's raining.
          • Addissimo
            • Mar 2004
            • 1820
            just go with racelogic
            the bmw system is a huge pain in the ass
            Doing something M50 related? -> http://www.addissimo.com
            On Myspace? ->http://groups.myspace.com/r3vlimited
            BF2142 SN = BillyGoose
            • Charlie
              kid tested, administrator approved
              • 6686
              See the pedal on the far right? That's BMW's analog traction control from the 80's. Depressing it further down reduces its effectiveness. If you ease up on it, you regain traction.
              Might want to try practicing that in traction-limited environments.
              -Charlie
              Swing wild, brake later, don't apologize.
              '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
              FYYFF
              • AdamF 88iS
                • 2051
                E30 ABS is 3 channel. ASCT needs a 4 channel system. You'd have to redo all the plumbing for the rear brakes, use an E36 ABS pump and control unit, some sort of full range throttle position sensor, and god knows what other tiny details are lurking. Just learn to drive.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • SpecM
                  • Oct 2005
                  • 4531
                  -What are the three channels? Left front, right front, and rears?
                  • Jordan
                    • 12916
                    Correct. e30 ABS is not capable of modulating the rear brakes independantly. Both or not at all.
                    https://mtechniqueabs.com/
                    • Addissimo
                      • Mar 2004
                      • 1820
                      sooo
                      once again
                      Racelogic
                      1400 with launch control,
                      1200 without
                      It'll probably be cheaper, and a hell of a lot easier.
                      • MrK
                        • Jan 2006
                        • 709
                        To all those who automatically assumed I couldn't drive, allow me to quell your fears. I race (on a track) on a regular basis, I have been for the last 6 years. So 'driving ability' is not an issue here.
                        I live in a country where a lot of roads are made as if they were an afterthought, with sudden dips and rough-spots in the middle of the freeways, which makes driving in the rain more dangerous than usual. In short, asc would only be an emergency measure of sorts if I encounter sudden irregularities in the road.
                        Thx to those of you who provided USEFUL answers. (Adam, Jordan, Addissimo, et al)
