Running an M20 without valve-cover breather
  • ryan_george
    • Mar 2004
    • 331
    I've been noticing quite a bit of sludge building up in my throttle body, and it's all coming through the breather hose from the valve cover. The sludge is making its way throughout the intake and I assume my pistons/cylinders are loving it
    Will there be anything wrong with just venting the breather hose to the atmosphere? I'd block off the port at the throttle body and just run a hose (with filter?) from the valve cover to the atmosphere somewhere....
    I can't see anything wrong with this, do you??
    -Ryan
  • chuckybob
    • Aug 2004
    • 952
    tuned m10s run the breather hose to the atmosphere under the car, from what ive read, the only negative side effect is the bottom of your car getting dirty(er).
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
      • 34847
      aside from maybe emissions issues, no. just make sure you don't cause vacuum leak..
      • ryan_george
        • Mar 2004
        • 331
        Great. That's what I was hoping for.
        I can take care of the mess and any possible leaks.
        Thanks.
        • Jordan
          • 12916
          There is nothing wrong with venting the valve cover breather, except that it crankcase on e30's is under vacuum because of the connection at the TB. If you block off the TB you should have no problems with it.
          Having it vented like that will introduce alot of moisture into the crankcase just so you know.
          https://mtechniqueabs.com/
          • BCMike
            • Oct 2005
            • 117
            You're treating a symptom, not the problem. It should really just be clean oil and a touch of combustion chamber gas in the uper head space. IMHO you should be more interested in figuring out why so much "sludge" is being produced in the upper head. I'd be thinking about how the valves are seating more than anything else.
            Let's go exploring!
              • 37833
              I don't run that vent tube, no issues
              Grover Beach, California
              BimmerHeads.com
              • EtaSport
                • 2853
                I'd suspect rings and poor oil in addition, possibly even condensation. If the passage is obstructed, there will be high crank pressure which can cause more blowby.
                Aren't you running an oil/air separator jordon?
                Old and improved:
                • Jordan
                  • 12916
                  Yes.
                  • ryan_george
                    • Mar 2004
                    • 331
                    I realize that there is something more to the problem, but this is to ensure that I minimize any further damage.
                    I have a feeling that it's sand that's sludging up.... Sand from when the valve cover was sandblasted.
                    I took the cover off to have a look at the head/rockers/cam, and everythting was very clean. No buildup anywhere. I took the cover and gave it a thorough soaking, and there was lots of debris (sand/sludge) coming from within the baffle.
                    I believe my problem lies within the baffle on the valve cover. And on that note, what's behind the sheet metal? If I drill out the rivets holding it on, am I just asking for trouble?
                    -Ryan
                    • kowalski
                      • Jan 2005
                      • 1791
                      -Ryan
                      well i hope you your engine isn't fucked up, if you got any sand in there you can kiss it goodbye... i don't know about the M20 cover, byt my m42 one had a rubber gasket on the top, and i took it off, cleaned it, and put a bead of scilcon all the way arround and it fixed my oil problem.
                      • e304me
                        • Feb 2006
                        • 1374
                        Would a catch can also do this or would just a single filter stuck onto the valve cover do it?
                        thanks
