No power to window switches
    Hey all
    Over the weekend my window switches stopped working. Power is going to the window switch breaker, but not to the switches.
    Has anyone had this issue before? Any advice?
    What could possible be between the breaker and the switch that could have gone wrong? I really don't want to end up re-wiring this.
    Your help is appreceiated.
    -Trevor
    2001 740i - daily
    1987 528e - project
    1987 325e - sold
    if u dont like my post click here
    have you tried replacing your actual switches? theres a fuse/relay 9dont remember) that controls your mirrors and windows so if your mirrors work im guesing its your switches
      thanks for the suggestion but yes.. i changed my switches. that was the first thing i did.
      2001 740i - daily
      1987 528e - project
      1987 325e - sold
        faulty breaker?
        89 E30 S52
        Transaction Feedback.
          Originally posted by bernzpeed View Post
          faulty breaker?
          do breakers fail for no reason? good suggestion though- didn't think of that. I'll swap one out tonight and see if that's the case.
          if not, does anybody else have other ideas on what the issue might possibly be?
          2001 740i - daily
          1987 528e - project
          1987 325e - sold
            there is the fuse diagram, id check everything related to the switches
              I'd be down for a faulty breaker as well. Check to make sure there is power on both sides of the breaker when it is in the "on" position.
              And yes, the breaker can fail.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
                check the child safety button on the console? Seems simple, but worth a look.
                "just love those little tanky inline 6's"
                  This is perfect.
                  Use a testlight, not a meter. The testlight will show for a fact that there is power in the circuit, while a testlight only shows voltage. There is a decent one at Wal-Mart for $5, 3M brand, heavier duty than most cheapies.
                  Remember that only 2 circuits in the whole car run on the "Unloader" relays, thats the HVAC fan and the windows. The starter controls the unloader relays, as bizarre as that sounds. That is what the green/black wire coming off the starter is for, it shuts down the windows and heater fan when the starter is running. EDIT: does your heater fan work properly? if so, the unloader circuit works, perhaps a bad K7(iirc)?
                  Good luck.
                  Luke
                  Closing SOON!
                  Thanks for 10 years of fun!
                    my e30 had a wire grounding somewhere next to the shift knob..my window switches only worked if i moved the stick all the way to the right so try playing around with the stick as ur messing with the switches
                    93 325i 120k
                    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
                    future mods: chip, m3 cams, headers, turbo
                      Yes, this too, that ground point has failed on more than a few E30s
                      Closing SOON!
                        bump for resolution?
                        BLUE NOSE - M62 SWAP
                        THE E30 + 1 BUILD
                          beezy
                          THE E30 + 1 BUILD
                            Originally posted by StereoInstaller1 View Post
                            This is perfect.
                            Good luck.
                            Luke
                            Hey Luke are you suggesting this may be a relay? My HVAC and everything on my speedometer (except MPH) stopped working days after the window switches failed. I'll check the relays and everything and update with my findings.
                            -Trevor
                            2001 740i - daily
                            1987 528e - project
                            1987 325e - sold
                              Pull your window breaker out and put a jumper wire in between the two wires it's most likely the breaker I just replaced my g/fs she had the same problem
                              -His-
                              87 e30 325i
                              87 e24 m6
                              05 e83 x3
                              94 e32 740i 5spd
                              -Hers-
                              89 e30 325i
                              18 f48 x1
