Is it okay to remove Driveshaft Tunnel Brace?
  • LagunaSecaBlue
    • Sep 2013
    • 360
    I just got an exhaust put on and it is rattling on my Driveshaft Tunnel Brace. Is it okay to remove the brace or are there any remedies to stop the rattling?
    #AZE30
    1991 318i
    1989 325i
    1989 335i
  • einhander
    • Apr 2004
    • 2024
    Are you re-using your old hangers? They could be sagging if so.
    2011 1M Alpine white/black
    1996 Civic white/black
    1988 M3 lachs/black
    • SlamedIAm
      • May 2011
      • 318
      Are you referring to the center support bearing? If so absolutely not. You'll trash your guibo and possibly damage the driveshaft over time.
      Replace any worn exhaust hangers and if that doesn't solve your rattle bring it back to your exhaust shop.
      • LagunaSecaBlue
        • Sep 2013
        • 360
        Not the CSB brace. The Brace infront of that. Its a large brace that bolts on top of the head shield. The only thing supporting the exhaust is the rear hanger and muffler holder. For some reason Magnaflow put a brace that hangs in mid air on their bolt on Cat.
        #AZE30
        1991 318i
        1989 325i
        1989 335i
        • bmwman91
          • Oct 2004
          • 3134
          It's a chassis stiffener, probably should not remove stuff that was put there for a reason to make an aftermarket part fit.
          Transaction Feedback: LINK
          • Dj Buttchug
            • Jun 2010
            • 7688
            you CAN remove that brace, but its dumb to do so. Ive driven cars without one. You cant really notice a difference.
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • LagunaSecaBlue
              • Sep 2013
              • 360
              I am only doing it for a short amount of time so I can fix the rattling.
              #AZE30
              1991 318i
              1989 325i
              1989 335i
              • jalopi
                • 2370
                Had to ditch it for the transmission I'm using... no problems.
