89 325 gas gauge
  • turk1shk1d
    • Oct 2013
    • 119
    89 325 gas gauge
    Hey guys.. I got a 89 325i... my gas gauge keeps playing around... my gas ligth does go on when it almost empty so what is the problem does anyone know? And also my fan doesnt work the temp starts going up went im on idle for a while.. what would be the reason?
    Sent from my SGH-M919 using Tapatalk
  • Gregs///M
    • Mar 2012
    • 2459
    Tighten the 7mm nuts behind each gauge, start there.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • ArtClassShank
      • Jul 2013
      • 143
      What Greg said. Also check your ground points on the board within your gauge. Mine were worn down, a bit of solder on each one and they work perfectly.
      Refer to this
      For your fan, could be the switch or a bunch of other things.
      1989 Carbon Black 328is
      • LagunaSecaBlue
        • Sep 2013
        • 360
        I can vouch for this. I just did mine today and it worked. Both my Gas and Coolant Gauge now are stable and accurate.
        #AZE30
        1991 318i
        1989 325i
        1989 335i
        • turk1shk1d
          • Oct 2013
          • 119
          Thanks guys.. I will try that
          • turk1shk1d
            • Oct 2013
            • 119
            Also my glove box wont open.. is there a easy way to open it without damaging anything?
            • Sea Aych
              • Apr 2013
              • 765
              My gas gauge always drops down way too fast and sits on empty while the OBC (when i press 1 and 1000) shows i still have 15 litres or so left... could that be a 7mm nut issue, or is either the gauge or the sensor shot?
              is the latch jammed or locked?
              1988 Atlantisblau Euro/Japanese 325i Cabriolet
              1989 Schwartz 325i - now M50 powered! - now very dead
              1998 Toyota 4Runner Limited
              My 17,000km Big NA National Parks trip!
              • turk1shk1d
                • Oct 2013
                • 119
                Yea the latch is jammed.. I put the key in to unlock it but I dont think it works
                • Sea Aych
                  • Apr 2013
                  • 765
                  Found this on bimmerfest:
                  "First of all you will need a new glovebox lock because its broken. That's why it won't open. Second, you will need a couple of long and narrow blade screwdrivers and 10 mm socket and/or wrench. You have to get down under the glovebox and find the three (3) nuts that hold the back hinge in place. They might be hidden under carpet and/or insulation but they are there! After you release them, the glovebox won't open but will move around some allowing you to reach with the screwdrivers and depress the "teeth" of the lock that engage in the dash metal bracket. Some people also remove the bolts that hold this bracket but I never did it this way. Watch out for the glovebox once it releases because is going down! Install your new (or used "new to you" latch), reattach the three nuts on the back (don't tighten them as you WILL need to move it around to get it to close prefectly again!) and adjust as required, tighten and enjoy!"
                  alternatively you could break the latch handle off and try and use a flathead to move the metal latch itself. latch handles are pretty easy to come by in the classified section it seems!
